Thread Number: 78926
/ Tag: Vintage Dishwashers
How to reset Kitchenaid Kds-19? |
Post# 1028870   4/3/2019 at 19:35 (1,849 days old) by 777funk (Mo)   |   | |
After a load, I've noticed I have to wait for non heated Dry before I can start the next round and often the drain motor comes on first. Is this normal? |
Post# 1028982 , Reply# 4   4/4/2019 at 19:19 (1,849 days old) by bigalsf (Salt Lake City)   |   | |
Here is one timer for $75: CLICK HERE TO GO TO bigalsf's LINK on eBay |
Post# 1028984 , Reply# 5   4/4/2019 at 19:27 (1,849 days old) by bigalsf (Salt Lake City)   |   | |
This one is $95. This is the one under the Whirlpool name, but it is the replacement timer for the original (it looks a little different). CLICK HERE TO GO TO bigalsf's LINK on eBay |
Post# 1028985 , Reply# 6   4/4/2019 at 19:31 (1,849 days old) by 777funk (Mo)   |   | |
Thank you very much for the reply. So if we open it prior to the non heated Dry completion and hit cancel, it should allow us to unload, reload l, close the door, and hit Go for the next cyclel? |
Post# 1029003 , Reply# 9   4/4/2019 at 21:53 (1,848 days old) by DADoES (TX, U.S. of A.)   |   | |
Not sure I'm recalling correctly but my 22-series Superba *may* have had one increment of pause at end of the dry period before it shut fully off. Canceling a cycle: - if it was any any point *prior* to the drain after the final rinse, the timer fast-forwarded to there and drained for one increment (either 1 min or 1.5 mins) - then it fast-forwarded to the last increment of dry which ran the blower (presumably without heat, perhaps as a cool down for the drying heater element?). It also ran this one increment of dry at the end of a Rinse/Hold. *- one increment of pause (with the Dry light still on)* - then the timer advanced again and the cycle lights turned off Raising the handle ran the timer for just a moment to move it to the start position in preparation for pressing a button for the next cycle. Don't raise the handle until the cycle lights turn off. |
Post# 1029018 , Reply# 10   4/5/2019 at 07:07 (1,848 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
The most common problem we have with these DWs as they age is the push-button cycle switch getting balky and not resetting as you open the door.
As you lift the latch a lever on the right side pushes a tab on the left end of the PBCS, this pops the chosen cycle button back out and allows the the timer to advance one last increment to the starting position.
If your PBCS is getting balky spray lots of electrical safe silicone lubricant in it and see if that helps, it also often helps to use a different cycle from the one that is always used [ usually this means going from normal to heavy or soak&scrub etc. ]
John |
