Thread Number: 78933
Life Expectancy of Bearings on Speed Queen or the good older washers? |
Post# 1028975 , Reply# 2   4/4/2019 at 18:50 (1,940 days old) by combo52 ![]() |
![]() 3
![]() Right On Brendan, Almost no washer ever built had bearing problems TILL water gets in them, So a better question might be which washers have the best water seals and overall life as a result.
Traditionally older top load washers with sleeve bearing [ at least for the top bearing closest to the water ] lasted longer.
This type of design would apply to MT DC, WP BD & DD, GE FF, WCI-Franklin. Machines with a ball bearing at the top usually had earlier failures, these included SQ TL perforated basket machines 1981 on , Norge perforated basket machines 1964 on, FD 1-18 washers however both FD and SQ solid tub washers did much better with top bearing life even with a ball bearing at the top and bottom.
John |
Post# 1029008 , Reply# 4   4/5/2019 at 00:50 (1,939 days old) by FreshNclean (WA)   |   | |
Is there any that comes to mind ? |
Post# 1029017 , Reply# 5   4/5/2019 at 06:43 (1,939 days old) by combo52 ![]() |
![]() 3
![]() Unfortunately it often takes time to see which machines are holding up best, the ones we have seen the most problems with over the last 10-15 years are.
Early MT Neptune's till they redesigned the seal a few years in. [ their orignal design had a face type lip seal, when I was in service training for this machine I told them it would not last long ]
Small door Frigidaire machines 1996-2011, had more than their share of bearing failures and broken spiders.
We saw a lot of bearing failures in the Chinese built LittleSwan GE washers and again quite a few broken spiders.
Frigidaire seems to made an impressive comeback, I don't think we have seen a single seal-bearing-spider failure in their next two generations of FL washers, however they still have lots of board [ motor and control ] failures door lock problems, clogged impossible to get sumps and just overall mediocre performance.
Overall I would say the quality and durability of main seals have improved in newer FL Washers.
John |
Post# 1029034 , Reply# 6   4/5/2019 at 10:14 (1,939 days old) by PinkPower4 (USA)   |   | |
What about the SQ top load LWN432 model. It should be similar to bearings found in the AWN432 series sold for home use??? Thanks |
Post# 1029156 , Reply# 8   4/6/2019 at 21:10 (1,938 days old) by stricklybojack (South Hams Devon UK)   |   | |
![]() 2
You can get a Speed Queen front loader now, just not the home version: www.appliancesconnection.... Or the old design TL machine: www.appliancesconnection.... |
Post# 1029203 , Reply# 10   4/7/2019 at 11:23 (1,937 days old) by combo52 ![]() |
