Thread Number: 79014
/ Tag: Modern Dryers
No Heat Kitchen Aid KDTE104ess1 |
Post# 1029699   4/12/2019 at 19:50 (1,932 days old) by IIIJohnnyMacIII (North Carolina)   |   | |
Post# 1029706 , Reply# 1   4/12/2019 at 21:02 (1,932 days old) by combo52 ![]() |
![]() 4
Post# 1029718 , Reply# 2   4/12/2019 at 21:47 (1,932 days old) by IIIJohnnyMacIII (North Carolina)   |   | |
Post# 1032346 , Reply# 3   5/10/2019 at 21:03 (1,904 days old) by vacman1961 (North Babylon, New York)   |   | |
Did you try resetting the board, the heater could have shut off. Check for error codes, the no heat error code is 7-1. |
Post# 1032835 , Reply# 4   5/16/2019 at 21:06 (1,898 days old) by IIIJohnnyMacIII (North Carolina)   |   | |
Post# 1032847 , Reply# 6   5/16/2019 at 23:27 (1,898 days old) by IIIJohnnyMacIII (North Carolina)   |   | |
Post# 1032854 , Reply# 8   5/17/2019 at 00:59 (1,897 days old) by IIIJohnnyMacIII (North Carolina)   |   | |
That's too bad. Should have a longer service life for sure. I feel your pain. It's terribly frustrating. Sounds like Whirlpool's overseas part supplier for control boards made some bad boards.
The Kenmore has a different control panel and control board! It has the same pump and motor assembly as my old KitchenAid. It has the same exact top and bottom racks. It's the same when it comes to noise level. Very quiet. It doesn't have prodry, but the only units that had prodry were top control and I wanted front control. I'm not sure if those top control units were using the same boards as my KitchenAid. I couldn't find a parts manual and didn't want to take the chance. Good luck. If you have anymore questions let me know. |
