Thread Number: 79059
Maytag A412 Series 02 |
Post# 1030074 , Reply# 1   4/16/2019 at 16:20 (1,836 days old) by qsd-dan (West)   |   | |
Welcome!
Your 412 is a one speed washer built between 1985-1989 and should have 4 button water level and 3 button temperature options. Your problems sounds simple: The tub is going out of balance. You have 2 options: Evenly distribute the load if washing multiple articles of clothing when it goes out of balance. Add more laundry to the tub if washing only one item (particularly a large and bulky item). This will help keep the tub balanced during the spin cycle. Stick a ruler or something of the proper thickness between the back of the lid and lid switch when this happens and you'll be able watch the drama unfold. Make sure the machine is level in all directions and the tub should be centered with the opening when the load is finished |
