Thread Number: 79102
VMW WTW4930XW1 Trouble |
Post# 1030353   4/20/2019 at 15:28 (1,924 days old) by DADoES ![]() |
![]() At one of RJ's rental properties. Complaint: Not working. Secondary complaint: Dryer takes too long. Fault Codes: F7 E1 (basket speed sensor fault); F7 E5 (motor unable to reach target RPM) Observation: Agitator runs in only one direction (clockwise), does not oscillate. No spin, basket is locked/jammed, cannot be rotated by hand at any time, whether actuator/mode shifter is in agitate or spin. Diagnosis: No spin/jammed basket = broken splutch or bad transmission? Agitation failure = bad transmission or bad capacitor? Have not yet pulled machine out for examination. Waiting for confirmation whether tenants need it to get caught up on laundry (without consideration of it not working, LOL), and/or whether one of my spares will be temporarily swapped-in. |
Post# 1030373 , Reply# 3   4/20/2019 at 20:17 (1,924 days old) by DADoES ![]() |
![]() The shifter/actuator seems to work. It clicks/clacks when selecting agitation or spin in diagnostics. This is the machine that previously had a small bootie-sock jammed in the pump ... so it's a given that the tenants overload it (although I "sternly" instructed them against it after the sock incident). There are no local parts sources, anything needed must be ordered. I have a spare pump, ordered one at the sock incident when finding that it didn't run, before pulling the machine down to investigate ... kept the new pump for future use. Haven't yet heard back from the tenants regards to swapping-in a loaner machine, so the VMW isn't yet out for investigation. Surely will pull the basket to check for a stray item. If that solves that problem, maybe will order both a capacitor and actuator. |
Post# 1031027 , Reply# 4   4/27/2019 at 20:30 (1,917 days old) by DADoES ![]() |
![]() Model-year 2010. Serial 2012 16th wk. Fetched the machine this afternoon for examination (swapped-in my GSQ9669LW1 for the interim, which is 9 years older and in 1000x better condition, LOL). The basket that was previously locked-up-tight somehow corrected during the past 7 days. It had a slight drag when I first checked it today but then loosened-up to feel normal. It still doesn't spin. Manual diagnostic, High or Low spin, it makes the slightest nudge, and nothing. The lid lock then won't release unless the power cord is pulled/reconnected. The lock does release after any other manual diagnostic test, just not after a spin attempt. It still doesn't oscillate for agitation, only runs clockwise. Pulled the basket just to see, no piece of clothing or other foreign object under it. The capacitor seems to test good if I'm doing that correctly ... ohms mode, reads 0 then infinity on each swap across the terminals. I suppose that doesn't necessarily mean it's good. The actuator/mode shifter shifts for both agitate and spin. Is it perhaps bad regards to the RPM sensing function? Same fault codes as before. Note in the pics, the cracked back edge of the tub, broken top edge of the tub ring in the same area, and the lower edge of the tub ring is broken such that there's no anchor on three of the tub tabs. Mystery how that happened. Pic 13 shows the crack-out on the edge of the tub beneath the tub ring in normal position. Pic 14 I'm pulling upwards on the tub ring. |
Post# 1031028 , Reply# 5   4/27/2019 at 20:34 (1,917 days old) by chetlaham ![]() |
Post# 1031032 , Reply# 6   4/27/2019 at 20:49 (1,917 days old) by henene4 ![]() |
Machine won't unlock after a spin was attempted unless it can verify the tub is standing still. During agitation tests it locks into agitation and won't check for motor rpm probably, and reversing for agitation might depend on rpm checks. Is the agitation intermittent or a continous movement? |
Post# 1031072 , Reply# 7   4/28/2019 at 08:37 (1,916 days old) by DADoES ![]() |
![]() Considering the age ... oh my! It's only 7 years per the serial. RJ bought it used 3 years ago from a local WP dealer. Their story was that it needed a repair for a part that was on backorder and the customer didn't want to wait so bought a new machine, and they (the dealer) sold the machine (after the repair) as a used/refurb. I've zeroed-in on the capacitor as the problem, I think. Agitation is intermittent motor operation as it should be, it just runs in the same direction on each pulse. I could be wrong but I don't think the RPM sensor is involved in agitation. Spin test, the motor nudges a bit then quits as if it's trying but can't get going. Apparently I wasn't waiting long enough for it to unlock. What happens after a spin test in Diagnostics ... any further agitation or spin tests (that involve motor operation) or lock/unlock test results in all the lights flashing together quickly three times --- flash-flash-flash -- then the lights for the selected test function flash slowly. Non-motor tests (inlet valves or pump) operate the target component. I waited longer after a (lock)/unlock test and it did unlock.
Post# 1031582 , Reply# 9   5/2/2019 at 15:21 (1,912 days old) by DADoES ![]() |
Post# 1031688 , Reply# 10   5/3/2019 at 12:49 (1,911 days old) by DADoES ![]() |
![]() RJ's reaction is ... they (the tenants) are used to it (the noise) by now and with my luck something else major will go wrong if the transmission is replaced so let's put it back there as-is. Is there a potential for leaking on the floor through the compromised tub seal & bearing? He has wood laminate flooring at that rental (yes, in the laundry closet). The tenants aren't going to notice a small drip/leak which can do enough damage over time to be a problem. I found a transmission for $150 incl shipping. Thing is I have a spare new pump from the previous jammed-sock incident (which I've swapped-in and it runs much better than the original pump), and also already invested in the capacitor and a tub ring. The machine isn't worth $325 for repair when a new Amana at Home Depot is going for $397 or a Roper at Lowes for $399. A few used transmissions for much less are on eBay but I don't trust used condition on that item. Both sisters have VMW machines (one is a Kenmore also at a rental property, the other an Amana but 6 hrs away) so the pump and capacitor (if both take the same items) work as a spares for those ... |
Post# 1031700 , Reply# 11   5/3/2019 at 15:58 (1,911 days old) by Lorainfurniture ![]() |
![]() 2
Don’t fix it. It’s never just the gearcase. There are some pieces that you will likely have to break to remove the gearcase. |
Post# 1031729 , Reply# 12   5/3/2019 at 19:30 (1,911 days old) by DADoES ![]() |
![]() I don't expect RJ will want the repair done ... I don't have the space to store another refreshed machine so am unlikely to do it for myself. I'm curious, what all parts/pieces may need to be broken for the removal? I suspect the drive pulley would be an effort to remove and possibly break in the process. I've already removed and reinstalled the agitator and basket. I'd expect the basket drive block would need refreshing. |
Post# 1031747 , Reply# 13   5/3/2019 at 23:06 (1,910 days old) by combo52 ![]() |
Post# 1033562 , Reply# 14   5/24/2019 at 20:13 (1,890 days old) by DADoES ![]() |
![]() 2
![]() I asked RJ last week "What am I supposed to do with the machinery on my patio?" "I thought you're fixing it." OK, allrightythen. Found a transmission for $119 and some cents from an online source, under an older part number. Add a basket drive block and extra shipping for the "large" item, total $159. As Combo says above, it's an easy-enough job. |
Post# 1033563 , Reply# 15   5/24/2019 at 20:15 (1,890 days old) by DADoES ![]() |
![]() 3
Post# 1033565 , Reply# 16   5/24/2019 at 20:40 (1,890 days old) by DADoES ![]() |
![]() 3
![]() How the splutch drive works ... 1) The agitate (inside, metal) and spin (outside, plastic) drive shafts are concentric. 2) Splutch spring. The basket drive gear sits atop the cam ring in the splutch housing. The ring and housing have molded bosses that lift or lower the drive gear when the ring rotates forward or back as controlled by the mode shifter / actuator. 3) Spin position, the basket drive gear is lowered. 4) Agitate position, the basket drive gear is raised. 5) The basket drive gear mates to the outer basket drive on the transmission. 6) The transmission drive pulley mounts to the inner agitate drive shaft on the transmission. It has splines molded into the top surface. The basket drive gear is lifted up away from the pulley splines when the mode shifter is in agitate position so the pulley drives only the agitate shaft (the basket drive shaft rotates/indexes during agitation due to friction between the shafts and lack of a brake to hold the basket from turning). The basket drive gear is moved down to mate to the pulley splines when the mode shifter is in spin position, which has the pulley driving both the agitate and spin shafts on the transmission. 7 & 8) Mode shifter / actuator. The two white plastic pieces at the left is the RPM sensor. It fits up into the slot in the transmission housing and optically reads the rotation of the basket via the notched gear that's coupled to the basket drive. |
Post# 1033566 , Reply# 17   5/24/2019 at 20:41 (1,890 days old) by DADoES ![]() |
![]() 3
Post# 1033572 , Reply# 18   5/24/2019 at 22:07 (1,889 days old) by IowaBear (Cedar Rapids, IA)   |   | |
Post# 1033716 , Reply# 20   5/27/2019 at 03:40 (1,887 days old) by DADoES ![]() |
![]() 3
![]() The load on the mode shifter is essentially only the force of the spring and the force needed to move/lift the cam ring over the housing bosses. There is no "slipping" spin clutch ... neither a clutch lining nor a slipping belt. Spin is a positive drive via the spin gear splines mated to the drive pulley splines. Spin acceleration is handled via motor torque and RPM. |
Post# 1034164 , Reply# 21   6/1/2019 at 19:15 (1,882 days old) by DADoES ![]() |
![]() The machine runs the auto-test cycle OK, Rinse & Spin no trouble, full Normal/Light cycle, no trouble. However, calibration fails. Pump on, lid locks, actuator shifts to agitate, a few agitation strokes, actuator shifts to spin, the pump continues to run and nothing else happens. Turns off after 5+ mins either with all lights off, or in one case with all lights on. Or maybe always with all lights on until it times-out and powers fully off. It did run calibration successfully some months ago at the sock-in-pump incident. How important is a successful calibration? Everything I find online indicates fix is replace the machine board. RJ won't be impressed. Maybe I won't tell him, and eat that cost myself. |
Post# 1034170 , Reply# 22   6/1/2019 at 20:51 (1,882 days old) by murando531 ![]() |
![]() 2
This poor machine has been treated like crap. I’ll disagree to my grave that VMWs like this one are poor performing or poorly built. The 4800 model I had that was bought in 2012 is a fantastic machine both build and performance-wise, and since giving it to my aunt whose ‘98 WCI-Frigidaire finally gave out two years ago, it’s still chugging away washing 2-3 loads a day with 6 peoples’ worth of laundry. As much as I loved my Oasis-BravosXL and the Whirlpool WFW92HEF front load set I have now, I do sometimes regret letting that machine go. The only complaint I ever remember having about it was the lid lock; otherwise I was never disappointed in the cleaning or rinsing ability, and it could turn heavy loads over like a champ.
Post# 1034612 , Reply# 23   6/5/2019 at 21:09 (1,877 days old) by DADoES ![]() |
![]() The only vid I find on YouTube that shows the calibration cycle is Eugene/Lorain Furniture running it on an impeller model. Starts the pump, four agitation strokes, pump runs a bit longer, then shifts to spin mode, turns the pump off, and runs three spin accelerations/coast-downs, and runs a bit of water at some point. My specimen runs the pump, agitates, engages spin mode but doesn't shut off the pump or do any spins, and I think no water ... then eventually times-out and turns off. It runs a rinse/spin or drain/spin with no trouble so the mode shifter/RPM sensor apparently is OK. It also runs the automatic test cycle with no trouble. Presumably bad board but why doesn't that trigger any trouble during a cycle? |
Post# 1035243 , Reply# 25   6/13/2019 at 12:15 (1,870 days old) by DADoES ![]() |
![]() I changed the control board, same result on Calibration ... so I assume that's correct behavior on this model?? I watched this time all the way to the end: - Status lights flash a rolling pattern from right to left - lid locks - pump turns on - shifts to agitate mode - agitates four strokes - shifts to spin mode - pump remains on for 5-ish mins with no other action - pump off, all lights steady on - one brief spin acceleration - water runs a few seconds - turns completely off, lid unlocks |
Post# 1036127 , Reply# 26   6/22/2019 at 16:53 (1,861 days old) by DADoES ![]() |
![]() 2
Post# 1036349 , Reply# 27   6/25/2019 at 07:45 (1,858 days old) by Repairguy (Danbury, Texas)   |   | |
![]() 2
Looking at the broken tub and cover the shocks are definitely worn out and the machine has to be jumping around in spin unless that is old damage and the shocks have been replaced ( maybe was the issue the dealer repaired previously). Also if these machines don’t shift from agitate to spin or spin to agitate within 15 seconds something is wrong with shifter. I’ve replaced shifters to correct this issue but more often I’ve put silicone lubricant on the “splutch” parts that slide to shift making it easier to slide and solving the issue almost every time. Just my two cents.
