Thread Number: 79179
1984 Whirlpool not spinning |
Post# 1030979 , Reply# 1   4/27/2019 at 15:59 (1,825 days old) by Repairguy (Danbury, Texas)   |   | |
Post# 1030989 , Reply# 2   4/27/2019 at 17:13 (1,825 days old) by Greggandnancy (Enfield)   |   | |
Thanks for the quick response. Yes the bad solenoid with the red wire is on the Left. I will order a new wig wag. The old machines are built like tanks! Thanks again repairguy! |
Post# 1030998 , Reply# 3   4/27/2019 at 18:14 (1,825 days old) by Repairguy (Danbury, Texas)   |   | |
Post# 1031001 , Reply# 4   4/27/2019 at 18:32 (1,825 days old) by Greggandnancy (Enfield)   |   | |
Wow! Forgot to mention we have the matching dryer also. It is still running flawlessly. Will that last awhile longer? Is it costing alot more money to run than a newer one? |
Post# 1031009 , Reply# 5   4/27/2019 at 19:19 (1,825 days old) by Repairguy (Danbury, Texas)   |   | |
The whirlpool dryers are built very good as well. The motor may draw a little more amperage than a new one but other than that there’s not much difference, in my opinion anyway. But, I’m probably biased because I wouldn’t have anything new these days. If you keep the vent pipe clean it will run as efficient as possible for many years. This design came out in 1965 and is still being used today although built with cheaper parts. Congratulations for hanging on to a nice vintage set.
Post# 1031044 , Reply# 6   4/27/2019 at 21:50 (1,825 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
If used correctly [ not running the dryer any longer than necessary to dry the clothes load ] is not a bit more costly costly to run than a brand new machine if you are comparing to a new vented dryer of the same fuel type that you have now.
However if you have an electric dryer now you can slash your operating costs by switching to a natural gas dryer, or if you don't have NG you could get one of the new Heat-Pump dryers, but HPDs have not come into common use in this country yet.
John |
Post# 1031096 , Reply# 7   4/28/2019 at 15:41 (1,824 days old) by Supersurgilator (Indiana)   |   | |
Those are very nice machines. The energy difference between that old dryer and a new one would be marginal if anything IMO. I would prefer to just hang on to the older, better made unit! |
Post# 1031786 , Reply# 8   5/4/2019 at 14:10 (1,818 days old) by Greggandnancy (Enfield)   |   | |
I bought a wig-wag on eBay and installed it and the washer is working great! Thanks again for the help.
Post# 1031792 , Reply# 9   5/4/2019 at 15:15 (1,818 days old) by Repairguy (Danbury, Texas)   |   | |
