Thread Number: 79198
/ Tag: Vintage Dishwashers
Advice needed: KDS-57A dishwasher leaking on wash cycle |
Post# 1031205   4/29/2019 at 11:17 (1,824 days old) by kevin313 (Detroit, Michigan)   |   | |
Friends,
I need some help and advice on my Kitchen Aid KDS-57A portable dishwasher. I purchased this a number of years ago and never ran it until this past weekend. Before running for the first time, I put a couple gallons of hot water inside and closed the door and let it sit for 2+ hours. There were no leaks. After I hit the "Cancel/Drain" button and the machine emptied completely of water and shut off. I put in some dishes and detergent and tried it on a full cycle. The pre-wash cycle went fine. When it moved to the wash cycle, the first few minutes everything was fine and then water started leaking out of the bottom of the door. I shut the water off from the sink and hit the "Cancel/Drain" button and it cycled through and emptied out completely. I tried it two other times with the same result. What is happening? Is there a seal I need to replace? Something else? If any of you know a fix to this I'd really appreciate it. The machine is in beautiful condition and I'd really like to use it. Thanks so much! |
Post# 1031208 , Reply# 1   4/29/2019 at 11:27 (1,824 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Hi Kevin. Try it again and if it starts leaking as before just open the door before turning off the water etc.
Then you can see if it is still filling [ stuck inlet valve ] or has it filled too full [ there should only be around two gallons of water in this DW ] or is there a lot of suds on the water surface ?
Post# 1031229 , Reply# 2   4/29/2019 at 14:33 (1,824 days old) by kevin313 (Detroit, Michigan)   |   | |
Post# 1031258 , Reply# 3   4/29/2019 at 18:32 (1,824 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Post# 1031265 , Reply# 4   4/29/2019 at 19:01 (1,824 days old) by Magic_Clean (Florida)   |   | |
lower rack front corner anti-splash clips are missing. Likely this is a factor. LP |
Post# 1031275 , Reply# 5   4/29/2019 at 20:36 (1,824 days old) by kevin313 (Detroit, Michigan)   |   | |
Post# 1031341 , Reply# 6   4/30/2019 at 10:26 (1,823 days old) by Tomturbomatic (Beltsville, MD)   |   | |
Hello Leslie! |
Post# 1031342 , Reply# 7   4/30/2019 at 10:39 (1,823 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Good eye Leslie, Yes these nylon clips helped prevent water splash from leaking under the door at the corners, You can try running it with a tee-cup saucer in the lower rack in each front corner and if the leak stops the lack of clips might be the reason for the leak.
If you need some clips I could send them too you. John |
Post# 1032452 , Reply# 8   5/12/2019 at 10:29 (1,811 days old) by kevin313 (Detroit, Michigan)   |   | |
John,
Thanks so much for the clips. Do I have them installed correctly ?
Post# 1032453 , Reply# 9   5/12/2019 at 10:43 (1,811 days old) by nmassman44 (Brooksville Florida)   |   | |
Yes those splash clips are installed correctly. That should help. I did notice too that the clips were missing in the pics at the start of the thread as well.
When i had that KitchenAid KDD67 portable many years ago, I took the clips off the corners of the lower rack not realizing how important those little darlings were. I took them off and ran a cycle, I can tell you that before the Main wash they were placed right back on. |
Post# 1032456 , Reply# 10   5/12/2019 at 11:07 (1,811 days old) by DADoES (TX, U.S. of A.)   |   | |
