Thread Number: 79207
Kenmore/whirlpool 28102 leaking |
Post# 1031462 , Reply# 2   5/1/2019 at 11:14 (2,205 days old) by DADoES ![]() |
![]() I have a Maytag/Bravos sibling (serial 2011) waiting a few years for a bearing job. It's partially disassembled but haven't worked-up the gumption to finish. I used the board-and-jack method to handle the stuck basket, haven't had that issue with any of the F&P units I've refurbed. None of the F&Ps -- circa 1999, 2004, 2005, 2008, and 2009 -- have as-yet evidenced bad bearings. |
Post# 1031544 , Reply# 4   5/2/2019 at 07:39 (2,205 days old) by combo52 ![]() |
![]() 2
![]() Hi Terry, I am glad it seems to be working now,
I could not comment or help with your orignal post because you did not include a good model #
PLEASE everyone if you are asking questions about a machine you are working on include a full model # off the tag on the appliance, if this is not possible a description of the appliance with approximate age helps and pictures are also wonderful.
John |
Post# 1031648 , Reply# 6   5/3/2019 at 03:09 (2,204 days old) by DADoES ![]() |
![]() 2
![]() 28102 is a partial model number ... actually more of a catalog number or stock number. The full model is (presumably) 110.28102310 A partial entry of a model number typically works as a wild-card search at SearsPartsDirect.com. It usually needs to start from the correct beginning of the model but a few characters in the middle may also work. In this case it needs the leading 110. or at minimum 110.281 which brings up three models one of which is correct. By your reference that it's a Whirlpool/Kenmore, anyone who knows Kenmore model coding would know the leading characters are 110. |
Post# 1033519 , Reply# 10   5/24/2019 at 03:12 (2,183 days old) by DADoES ![]() |
![]() 2
Post# 1033940 , Reply# 15   5/30/2019 at 06:20 (2,177 days old) by Combo52 ![]() |
Post# 1034006 , Reply# 17   5/30/2019 at 21:45 (2,176 days old) by DADoES ![]() |
Post# 1034015 , Reply# 19   5/31/2019 at 00:30 (2,176 days old) by DADoES ![]() |
![]() This design iteration doesn't have a physical off-balance switch. OOB sensing is via motor controller detection of basket rotation characteristics and perhaps cabinet impact detection if it has an accelerometer on the board like a Neptune TL. The RPS on the motor can be implicated in uL issues but I don't think that's very common. Nothing appeared broken on my suspension rods but there was no way to judge the dampening characteristics of the pneumatic cylinders. The tub would go to leaping like a bronco during spin acceleration, even with no clothes, bounce upwards and impact the machine top. It's an amazing difference with the new rods. |
