Thread Number: 79322
cold side of washer slowly keeps dripping |
Post# 1032487 , Reply# 1   5/12/2019 at 20:50 (1,811 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
You can try taking the valve apart and cleaning [ warning do not remove the inlet screens to clean, instead clean them in place, if you remove them they get bent slightly and will allow particles to pass by and cause the valve to stick open and cause a flood ] But I would not waste my time and effort as it will often either not work or fail again soon and possibility flood out your laundry room.
New valves are less than $30 |
Post# 1032490 , Reply# 2   5/12/2019 at 21:12 (1,811 days old) by oliger (Indianapolis, Indiana)   |   | |
Thank you. This washing machine is in the kitchen, so I will definitely replace it then! |
Post# 1032491 , Reply# 3   5/12/2019 at 21:19 (1,811 days old) by oliger (Indianapolis, Indiana)   |   | |
www.amazon.com/205613-Ken... Will this inlet valve work with my 806 machine? |
Post# 1032509 , Reply# 4   5/13/2019 at 07:12 (1,810 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
