Thread Number: 79594
/ Tag: Modern Dryers
Dryer Vent Hose |
Post# 1034919   6/9/2019 at 18:04 (1,874 days old) by Launderess ![]() |
Post# 1034921 , Reply# 2   6/9/2019 at 18:22 (1,874 days old) by DADoES ![]() |
Post# 1034929 , Reply# 3   6/9/2019 at 18:57 (1,874 days old) by Lorainfurniture ![]() |
In Europe people don’t use the dryer that much. Foil slinky vent is great if it’s just a short run. Rigid aluminum is the standard and hard pipe for the over achievers. |
Post# 1034932 , Reply# 4   6/9/2019 at 19:22 (1,874 days old) by thomasortega ![]() |
Other great alternative is a periscope if the space isn't generous. HOWEVER The periscope must be cleaned at least twice a year. |
Post# 1034933 , Reply# 5   6/9/2019 at 20:02 (1,874 days old) by Launderess ![]() |
Had one once for about a few months; darned thing leaked lint laden air like a sieve. Couldn't understand why area in back of dryer and or area surrounding was covered in layers of lint dust.
Took off and rubbished the thing, going back to venting with hose. In the end using the periscope didn't make that much of a difference in how close dryer could be pushed back, which was main reason for purchasing. Now that have the AEG Lavatherm on top of the Whirlpool has to be room back there anyway to ensure proper air flow. |
Post# 1034938 , Reply# 6   6/9/2019 at 21:00 (1,874 days old) by wayupnorth ![]() |
My Maytag electric 410 dryer is only used sparengly in the winter other than a clothesline and drying rack in the real cold weather. I do not vent the dryer outside permanently. I have a board to fit in the window next to it to seal the metal hose to go outside. Dryer off, window closed. I had an instance at my old house, forgetting to hit the start button until the next morning and bang, bang the whole load was froze because of the freezing cold coming thru that outside vent.
Post# 1034944 , Reply# 7   6/9/2019 at 21:51 (1,874 days old) by Launderess ![]() |
Post# 1034956 , Reply# 8   6/10/2019 at 05:28 (1,873 days old) by logixx ![]() |
I suppose European dryers don't get as hot as the US ones (around 120 to 140F, I guess) so plastic is fine. Besides, most people I know just hang the hose out of a window when using the dryer. I would also guess that the whole "venting/ductwork thing" is as popular, at least in Germany, simply because we don't have a need to run vents through our homes - no HVAC systems - and our houses don't lend themselves to running ducts through them in the first place, with the walls being solid stone. Even knocking a hole in the wall to vent your range hood requires some serious power tools.
Post# 1034957 , Reply# 9   6/10/2019 at 05:59 (1,873 days old) by DADoES ![]() |
![]() I can reach through the exhaust hood outside and touch the dryer's blower wheel. The dryer must be set at an angle to the wall because the outlet is too far toward the corner which obstructs the ducting as per Pic 2. |
Post# 1034970 , Reply# 11   6/10/2019 at 08:24 (1,873 days old) by deltablu (Eastern South Dakota)   |   | |
is the surface static that is generated by having airflow through it causing lint to stick even worse than it does in other types of vent. Also why rigid PVC is not recommended for dryer venting as well. |
Post# 1034971 , Reply# 12   6/10/2019 at 09:00 (1,873 days old) by logixx ![]() |
