Thread Number: 79634
GE Top Loader Lid Switch |
Post# 1035372 , Reply# 1   6/14/2019 at 19:36 (1,869 days old) by DADoES ![]() |
![]() 4
![]() Parts diagram indicates it is a magnetic (reed) switch. Item #30 (p/n WH44X27476). Somewhere under the top deck at whichever edge of the lid ... possibly on the left side. The location of the magnet on the lid is the clue, you may need a stronger tricker-magnet. Model GNW128PSM0WW Lid & Controls |
Post# 1035374 , Reply# 2   6/14/2019 at 20:08 (1,869 days old) by Yogitunes ![]() |
![]() 4
Post# 1035787 , Reply# 4   6/20/2019 at 10:43 (1,863 days old) by Yogitunes ![]() |
the only way to know, is by gaining access to lifting the top, and/or rear panel...
the Avanti had only one regular switch connected to the lid hinge on the left.... yet the MC had this, plus the reed/magnetic switch on the right hand side of the door opening.... I had to install two switches to operate/by-pass this with the lid open... |
Post# 1036085 , Reply# 9   6/22/2019 at 09:51 (1,861 days old) by PinkPower4 (USA)   |   | |
I wish I could go back and edit... The newer model does a rinse water level that seems to be equal to the wash level. |
Post# 1036155 , Reply# 11   6/23/2019 at 04:12 (1,860 days old) by thomasortega ![]() |
Btw, I have "only" 16 washers connected to only one hookup (and a world of hoses and Y connectors) and two washers sharing the drain standpipe and all the others draining in the laundry sink. Of course I have to keep an eye open because they can't drain all at the same time, but I learned how to start the washers at a certain sequence e to synchronize the drain times. |
Post# 1036169 , Reply# 13   6/23/2019 at 08:46 (1,860 days old) by sfh074 ( )   |   | |
![]() 2
Thread hi-jack! Maybe HotWater should start a new thread to get the answer he is looking for .... the reason he started this thread in the first place? |
Post# 1036170 , Reply# 14   6/23/2019 at 09:22 (1,860 days old) by Yogitunes ![]() |
your not filling in enough information.....
how many lid switch units does you machine have?....if it has two, using a magnet only while the lid is open, still wont work if the other is not bypassed... on the diagram, 30 is the reed switch.... 35 and 36 appear to be the OOB switch.... what is 37, pressure switch? and what about 2....what does that do?... your going to have to pop those top panels and have a look to see what your dealing with...your going to have to in any case if you want to by-pass them... who knows, by now, there could be 3 or 4 lid switches, anything is possible... never had to adjust water levels, all filled to the top for full level selections on the ones I have...
