Thread Number: 79680
/ Tag: Member Selling Item(s)/Non Professionally
Stove |
Post# 1035762 , Reply# 1   6/20/2019 at 05:01 (1,784 days old) by norgeway (mocksville n c )   |   | |
closer I could fix that in 10 minutes. |
Post# 1035768 , Reply# 2   6/20/2019 at 05:46 (1,784 days old) by Combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
It’s likely just some wiring connections the whole thing does not generally need to be rewired.
There are probably much better alternatives to having a gas stove inside your home. If you’re going to switch to gas make sure you’ve got a really good exhaust fan vent it out doors and use it even with just using the tea kettle to boil water. John |
Post# 1035828 , Reply# 3   6/20/2019 at 17:40 (1,783 days old) by suds14 (Pittsburgh)   |   | |
The wires for the burners are very brittle and will not stay attached. It is hard for me to switch, but It takes a long time to cook. |
Post# 1035839 , Reply# 4   6/20/2019 at 20:08 (1,783 days old) by LowEfficiency (Iowa)   |   | |
