Thread Number: 79810
Duet F20 and slow leak |
Post# 1037049 , Reply# 1   7/3/2019 at 17:34 (1,850 days old) by henene4 ![]() |
Would suspect the water valve, cold side probably. A broken valve often has verry wonky behaviour, sometimes not opening at all (F20 should be a no fill error code) or not closing properly (water in the tub). At least a failing pressure switch wouldn't cause water in a switched off machine... |
Post# 1037332 , Reply# 3   7/6/2019 at 17:02 (1,847 days old) by Launderess ![]() |
Most of these new fangled electronically controlled washers require not just replacing a part/correcting a fault that causes a code, but the machine must also be reset to clear said error/fault before machine will operate normally.
producthelp.whirlpool.com/Laundr... applianceassistant.com/Washer-Re... See also: |
