Thread Number: 79985
New WP combo with decent ratings and it's 220 volt. |
Post# 1039097   7/22/2019 at 16:10 (1,831 days old) by cuffs054 (MONTICELLO, GA)   |   | |
CLICK HERE TO GO TO cuffs054's LINK |
Post# 1039151 , Reply# 1   7/23/2019 at 09:30 (1,830 days old) by cuffs054 (MONTICELLO, GA)   |   | |
I wonder why they only offer it in one color and no white?
Post# 1039211 , Reply# 3   7/23/2019 at 19:32 (1,830 days old) by LowEfficiency (Iowa)   |   | |
![]() >>Now for the bad this unit seems exceptionally buggy About every 3rd/ 4th load it will toss a no water >>detected code in the middle of the was cycle to clear this code you have to unplug the unit wait a >>moment plug it back in and start the wash cycle all over kind of annoying but its better than a nasty >>dirty laundromat >> >>Now every once in awhile the thing will just go nuts... will run wash cycles fine it will go to start its >>dry cycle but fill itself up with water like a wash cycle often even dispensing soap too... will then >>throw up a no water code and sit full of water so you unplug reset and select spin cycle or rinse and >>spin and again it says spinning but the drums in was cycle and full of water... cancel cycle select spin >>cycle again ok great it spun this time now select dry cycle and it fills itself with water soaking the >>clothes again then tosses no water detected code again and no matter what you seem to do it wont >>cooperate with you... so you toss in the towel and hang dry that load a few days later you toss a new >>load in and in functions as it should or just makes you clear a no water code... >> >>Another thing ive noticed with the load and go dispenser is i constantly get low fluid warnings when >>its full about every other load it does this Sounds like they have some software bugs to resolve... Are these modern internet-connected washers able to update their firmware from remotely, or does it take a service call or a parts swap to do so? 3.1 out of 5 stars isn't great, especially when a number of those higher-star reviews are from people who got their machines for free... Also... "Default cycle time with regular wash and dry is 6.5 hours." I can see that being extremely limiting for a small machine to take so long. You probably NEED the wifi & app, so that you can plan your day around starting and finishing laundry when you are available. |
Post# 1039298 , Reply# 4   7/24/2019 at 15:01 (1,829 days old) by cuffs054 (MONTICELLO, GA)   |   | |
Washingpowder, It must engage the heater for the warm and hot washes also since it uses only a cold fill. I would be interested to know how different the dryer section operated versus 120 volt units. |
Post# 1039441 , Reply# 9   7/25/2019 at 17:44 (1,828 days old) by cuffs054 (MONTICELLO, GA)   |   | |
Some fun reading:
media.datatail.com/docs/manual/52... CLICK HERE TO GO TO cuffs054's LINK |
