Thread Number: 80072
/ Tag: Modern Dryers
How would you know if you needed to replace a gas regulator? |
Post# 1040124 , Reply# 1   7/31/2019 at 09:21 (1,822 days old) by Yogitunes ![]() |
there really is no adjustment....sort a preset position, and the spring will compensate as needed....
about the only time you open one up is to change from natural gas to propane....and that is only the cap that gets replaced... what makes you think this is causing your issue? could be your solenoids, even though power may come through, does not mean they are opening the valve....have had several faulty like this... I would go with the easiest stuff first.... |
Post# 1040204 , Reply# 2   7/31/2019 at 17:48 (1,822 days old) by Addle (Monmouth Co, NJ)   |   | |
I was just wondering why they had the repair video. thanks for answering my newbie question. |
