Thread Number: 80178
Top Load Design to Prevent Pump Clog or Damage? |
Post# 1041455 , Reply# 1   8/11/2019 at 20:01 (2,103 days old) by Yogitunes ![]() |
![]() 2
some machines...FL as well as TL have some sort of 'trap' before the pump...some don't!...
all the more reason to double check pockets and such before tossing in the machine... but still, a simple button could pop off during washing and make its way down to the pump.....some pump setups will accommodate small items, and pass them on through right down the drain... if you have ever cleaned out a dryer....enough can be found in there to create its own junk drawer! |
Post# 1041458 , Reply# 2   8/11/2019 at 21:01 (2,103 days old) by Lorainfurniture ![]() |
![]() 2
There is a “screen” kind of thing pre pump. Check your pockets is the best insurance |
Post# 1041573 , Reply# 3   8/12/2019 at 22:10 (2,102 days old) by DADoES ![]() |
![]() This is the tub outlet / pump protector on a VMW I repaired (new transmission, new pump, new capacitor) a few months ago. 1 = outlet cover 2 = looking into the pump from the tub outlet 3 = outlet cover installed 4 = beneath the installed outlet cover Year+ ago the pump got jammed by a small bootie-type sock that went over(load) the basket, presumably during the initial "load-balancing spin" at the start of a cycle. This protector/filter did not prevent the sock from passing into the pump. |
