Thread Number: 80340
/ Tag: Vintage Dishwashers
What kind of Hotpoint dishwasher is this |
Post# 1042825   8/27/2019 at 09:05 (1,704 days old) by volsboy1 (East Tenn Smoky mountains )   |   | |
I found this old Hotpoint dishwasher on Craigslist cheap. What is this?I have never seen a Hotpoint or G.E. with this type of set up.I don't see the inlet on the right side bottom.
Where they any good at washing? |
Post# 1042829 , Reply# 1   8/27/2019 at 09:19 (1,704 days old) by Frigilux (The Minnesota Prairie)   |   | |
Post# 1042831 , Reply# 2   8/27/2019 at 09:36 (1,704 days old) by pulltostart (Mobile, AL)   |   | |
Post# 1042915 , Reply# 4   8/28/2019 at 02:46 (1,703 days old) by toploader55 (Massachusetts Sand Bar, Cape Cod)   |   | |
The Cement Mixer...
Very loud when filling as the Cavitation will vibrate everything in the kitchen, And the snapping drain solenoid goes neck and neck with the KitchenAid 15-20 series My Dad had the Builder's grade little bit older model. Cleaning on a scale of one through ten... it gets a "Ehhhhh". Not really a pot scrubber, but dishes and glassware should come out clean if not "BobLoaded". |
Post# 1042929 , Reply# 5   8/28/2019 at 07:41 (1,703 days old) by Combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Very crude limited capacity lots of noise and lots of water consumed, but it sure beats not having a dishwasher at all
It could be a fun machine if you’ve never had the miss fortune to be stuck with one of these to get and play with now you can considerably upgrade the noise aspect of it by putting a decent newer style PSC motor in it. Rust and leaks around the door gasket were the major problems with this model and then the usual problems with the pump and motor and drain valve assembly itself other than that pretty rugged. But the machine itself is nowhere close to a nicer Whirlpool KitchenAid Maytag even the GE dishwasher with multi orbit wash were much better. John |
Post# 1042952 , Reply# 6   8/28/2019 at 11:21 (1,703 days old) by Washerlover (The Big Island, Hawai’i)   |   | |
