Thread Number: 80784
I splurged on something... |
Post# 1047782 , Reply# 1   10/15/2019 at 14:58 (1,746 days old) by vacerator (Macomb, Michigan)   |   | |
wanting a C-3 Brilliant, but a new central built in system here still costs a lot less than $1,500 US for the power unit, hose, attatchments, and power nozzle. |
Post# 1047807 , Reply# 2   10/15/2019 at 18:49 (1,746 days old) by appnut ![]() |
Post# 1047808 , Reply# 3   10/15/2019 at 18:57 (1,746 days old) by Frigilux (The Minnesota Prairie)   |   | |
Post# 1047883 , Reply# 5   10/16/2019 at 19:33 (1,745 days old) by Frigilux (The Minnesota Prairie)   |   | |
Post# 1048007 , Reply# 8   10/18/2019 at 05:49 (1,743 days old) by henene4 ![]() |
![]() 3
Pics first |
Post# 1048013 , Reply# 10   10/18/2019 at 08:12 (1,743 days old) by Frigilux (The Minnesota Prairie)   |   | |
![]() 2
Post# 1048042 , Reply# 11   10/18/2019 at 16:48 (1,743 days old) by henene4 ![]() |
Those are the 3 CapDos caps that were shipped with the machine. I'll get into those more at some point, ordered some together with the Miele UltraWhite that I got for free with a voucher that came with the machine. |
Post# 1048044 , Reply# 13   10/18/2019 at 16:57 (1,743 days old) by jerrod6 (Southeastern Pennsylvania)   |   | |
Henrik. Mine has the wide white ring around the door, but I much prefer your door with the silver ring. |
Post# 1048046 , Reply# 14   10/18/2019 at 17:15 (1,743 days old) by henene4 ![]() |
Not the source I girst thought off, but here is the copy I downloaded now: fliphtml5.com/jknmy/kxha/basic/35... |
Post# 1048300 , Reply# 16   10/21/2019 at 08:53 (1,740 days old) by henene4 ![]() |
Post# 1048304 , Reply# 18   10/21/2019 at 10:27 (1,740 days old) by ozzie908 ![]() |
I have the same machine but with out the WIFI connection did not see the point as at home when ever I use the machine.
What a lovely wash cycle its quiet efficient and does what you want. It spins brilliant too it makes my heat pump dryer much faster and the spin although the same as my old Miele seems to be able to remove more water as I notice I hardly have to empty the drawer in the dryer. Over all I am completely satisfied with the washer and what it cost. And for getting a free 5 year warranty not used the capsules that came with it and highly doubt I will. Austin |
Post# 1048424 , Reply# 21   10/22/2019 at 12:28 (1,739 days old) by henene4 ![]() |
Post# 1048556 , Reply# 22   10/23/2019 at 16:31 (1,738 days old) by johnb300m (Chicago)   |   | |
Very impressive...so much detail!
I'm blown away by how much detail and customization Meile allows on their machines. I was talking with another washer wonk recently how our American machines seem to be de-contenting features and displays and technical information. In exchange for more "bells and whistles." On many American appliances, especially dishwashers, a time or cycle progress indicator aren't even offered anymore. Many washer/dryer marketing materials and website omit whole technical explanations and descriptions. Whirlpool's new washer line doesn't even mention anything about a balance or suspension system anymore, wether the machine has balance rings or not. HECK, they don't really even specify belt or direct drive anymore. Dishwashers don't really explain all the characteristics of individual cycles anymore. LG seems to at least still be explaining some tech features.....but it's a lot less than it used to be, across the board. Now, it seems, if I want to learn about tech specs today, I have to dig and hunt around on replacement part sites, or pour through patent documents. Alas, well wishes on this really awesome washer. |
Post# 1048607 , Reply# 23   10/23/2019 at 20:14 (1,738 days old) by DADoES ![]() |
Post# 1048664 , Reply# 28   10/24/2019 at 13:40 (1,737 days old) by Logixx ![]() |
At least the European programming does indeed drain out "excess" water - at least under certain circumstances. The advantage is that the energy consumption is low, yet the laundry is heated to the set temp, while all other washers don't reach the target on the Eco/ Energy Label cycle.
Also: my Duet has a flow meter. |
Post# 1048665 , Reply# 29   10/24/2019 at 14:23 (1,737 days old) by henene4 ![]() |
What I found with my software version at least is that the machine appears to try to avoid draining out water by ending the saturation phase with a slow tumble in either direction with the recirc on and not spinning after that before starting the drain. Thus most detergent and water go onto the clothes and spread about during the wash phase. |
Post# 1048773 , Reply# 31   10/25/2019 at 16:28 (1,736 days old) by jerrod6 (Southeastern Pennsylvania)   |   | |
Henrik and others in the EU: Can you give us an explanation of what and how Powerwash 2.0 works? I understand the first version of Powerwash and my W1 uses that. I've seen the Powerwash 2 term, and have watched videos of it but have no idea what I am seeing or why it is being done. Why is it good to use? |
Post# 1048855 , Reply# 32   10/26/2019 at 02:40 (1,735 days old) by Logixx ![]() |
Post# 1053223 , Reply# 37   12/5/2019 at 10:01 (1,695 days old) by ozzie908 ![]() |
I have to agree with you it really is a great washing machine and after reading your very complete list of what it does and when I have started using the cottons 60c the one that heats to the set temp, and using the intensive option and that makes a lot of difference to the wash rhythm as you say every thing comes out clean and whites are back to dazzling like they used to be.
I am still toying with getting the matching heat pump dryer as I have noticed my AEG 7kg dryer is taking forever to dry the loads the Miele washes its also creasing things up and taking me longer to iron soooooo I may treat myself in the new year :) Austin |
