Thread Number: 80853
Bleach Detergent? |
Post# 1048469   10/22/2019 at 20:54 (1,739 days old) by IIIJohnnyMacIII (North Carolina)   |   | |
Post# 1048478 , Reply# 1   10/22/2019 at 22:18 (1,739 days old) by DADoES ![]() |
![]() 2
![]() Cascade Institutional powder is one, which is now labeled as Cascade Fryer Boil Out. dishwasher detergent with bleach Cascade Fryer Boil Out |
Post# 1048485 , Reply# 3   10/22/2019 at 23:40 (1,739 days old) by Launderess ![]() |
![]() 2
Finish gel and powder dw detergent are still chlorine based.
Usually but not always anything marked "institutional" is old school chlorine based dw detergent (with or without phosphates). If you cannot find something in local shops, try any restaurant, institutional, commercial supply house. You may have to buy a rather huge tub of the stuff, but there you are then. IIRC Ecolab sells "Finish" institutional dw detergent. www.hpproducts.com/ItemDi... |
Post# 1048499 , Reply# 4   10/23/2019 at 05:01 (1,738 days old) by mark_wpduet (Lexington KY)   |   | |
![]() 4
that was recommended by someone else on this forum. When you're ready to run your machine with dirty dishes, put your detergent in the main detergent cup......close it and pour like a shot glass of liquid bleach on the dishwasher door, close it up, start it. I'm not sure what kind of regular dish machine detergent you use, but it shouldn't be affected by the bleach since it will be mostly rinsed away in the first water purge. I've been doing this for a LONG time now and it I use Finish powerball detergent, which has enzymes.....the machine smells santized and dishes are really clean. No tomato stains......I don't pre-rinse. OR....... You could be a bottle of chlorine-based detergent, pour a little in the prewash so that will give enough bleach action in the prewash to get those stains off.....but I like the regular bleach better. I think it keeps the inside of the dishwasher cleaner as well.
Post# 1048507 , Reply# 5   10/23/2019 at 08:47 (1,738 days old) by IIIJohnnyMacIII (North Carolina)   |   | |
I found some finish powder on Amazon! They don't sell it at my local stores. I hope they aren't phasing it out. I also might try the shot of bleach on the door in the meantime. I think putting it on the door will be key, because my Bosch does a purge before it starts the first fill. So are we talking about 1 ounce?
Post# 1048512 , Reply# 6   10/23/2019 at 09:10 (1,738 days old) by combo52 ![]() |
Post# 1048630 , Reply# 7   10/24/2019 at 07:20 (1,737 days old) by mark_wpduet (Lexington KY)   |   | |
just eyeball it....just pour a little on the door. I'm guestimating about a shot glass worth. Although, I didn't realize your machine purged before it starts to fill. My Maytag doesn't do that. It just starts to fill for the prewash, then purges. You will smell the bleach while it's running. A little LBC goes a LONG way.
Post# 1048643 , Reply# 8   10/24/2019 at 10:03 (1,737 days old) by Iheartmaytag (Wichita, Kansas)   |   | |
![]() It kind of defeats the "automatic" part of the automatic cycle, but you won't do if too often. Wait until after the main wash drains and then open the door and pour in a shot glass (1oz) or so of LCB, then resume the cycle.
This way you get the bleaching action, you don't have to worry about it interfering with the detergent's enzymes and in the process you get some disinfection action from the bleach.
Another thing you can do is place stained plastic ware out in the sun on a sunny day. I sometimes set a few pieces on the picnic table if the wind isn't too bad, we're talking Kansas here. The UV rays will naturally bleach out the red stains. |
Post# 1048737 , Reply# 10   10/25/2019 at 08:11 (1,736 days old) by mark_wpduet (Lexington KY)   |   | |
Back a few years ago when they took phosphates out of DW detergent people were having a hard time with the new stuff, but Finish powerball seemed to get good reviews. I Love it. That's all I buy from Cosco (the big container) and I have moderately hard city water with no water softener. I can understand those that have a softener might not be able to use the tabs. Someone on this forum said a long time ago to pour a little bleach on the door before starting the load. The first time I did it you could tell when the machine had finished and you opened that door everything just smelled cleaned and disinfected. And with just a LITTLE BIT of bleach. Been doing it ever since. Once I had a sample of Finish Quantum. I didn't like it because it foamed WAY too much. Cleaned well, but foamed too much. I felt like it was way too hard on the dishwasher as you could hear it struggling through the foam.
Post# 1048746 , Reply# 11   10/25/2019 at 10:59 (1,736 days old) by ozzie908 ![]() |
Not sure if you can get any sanitiser tablets I buy them from a cleaning company and you put 2 on the door they dissolve in the prewash and the main wash uses the pod it works as I have no more tomato stains on any plastic ware its been a problem here for some time ever since the ingredients in the pods changed.
Austin |
Post# 1048776 , Reply# 13   10/25/2019 at 16:52 (1,736 days old) by IIIJohnnyMacIII (North Carolina)   |   | |
![]() 2
Post# 1048783 , Reply# 14   10/25/2019 at 18:55 (1,736 days old) by pierreandreply4 (St-Bruno de montarville (province of quebec) canada)   |   | |
IIIJohnnyMacIII do not know if this will help you but found this on amazon www.amazon.ca/-/fr/Cascad...ŽÕÑ&crid=2NLNJSJXO14DW&keywords=cascade+dishwasher+soap&qid=1572047609&sprefix=casacade+dishwasher+%2Caps%2C142&sr=8-48
Post# 1048785 , Reply# 15   10/25/2019 at 19:04 (1,736 days old) by askolover ![]() |
Post# 1048881 , Reply# 18   10/26/2019 at 09:27 (1,735 days old) by Helicaldrive ![]() |
I tried Finish Quantum once and same thing — it foamed up, the D/W struggled with sudslock, and there was no spray action going on. |
Post# 1048891 , Reply# 19   10/26/2019 at 11:17 (1,735 days old) by DADoES ![]() |
Post# 1048896 , Reply# 20   10/26/2019 at 14:48 (1,735 days old) by IowaBear (Cedar Rapids, IA)   |   | |
![]() I had been using Cascade Complete pacs without issue but then the last batch I got was really foamy, much like the pictures and complaints here.
It's very annoying...P&G wants people to be brand loyal, but they seem to have forgotten the reason people are brand loyal is because they are expecting the product to work and smell the same way each time.
If you want a surprise you might as well buy whatever is on sale. |
Post# 1048960 , Reply# 21   10/27/2019 at 06:37 (1,734 days old) by askolover ![]() |
![]() The ONLY pacs/tabs I can use in my KUDI23 are Miele and Finish powerball with the hard red ball in the middle. EVERY other kind foams up too much with our water softener. The finish tabs don't etch as bad as the powder years ago but still will do it over time. I'd be hesitant in one of the new minimal water dishwashers because the detergent would be more concentrated with the smaller amount of water used. |
Post# 1048975 , Reply# 23   10/27/2019 at 10:11 (1,734 days old) by Helicaldrive ![]() |
For the answers, especially askolover. |
Post# 1049025 , Reply# 24   10/27/2019 at 16:50 (1,734 days old) by IIIJohnnyMacIII (North Carolina)   |   | |
Wasn't successful at removing the stains with Palmolive Eco. However, the detergent washed my dishes flawlessly, left no film or cloudiness, and with the cost I could wash my dishes for about $3/month!
These stains have been on my dishes for a while now, so I think I'm going to take the things that are already stained and soak them in a bleach solution and use the Palmolive Eco to see if it will keep things from staining from now on. Thanks for the recommendations! |
Post# 1050067 , Reply# 27   11/5/2019 at 22:41 (1,725 days old) by IIIJohnnyMacIII (North Carolina)   |   | |
Post# 1050096 , Reply# 28   11/6/2019 at 14:11 (1,724 days old) by Rolls_rapide (.)   |   | |
I had a look on Amazon UK's site. Other folk have also commented about Finish Quantum Ultimate's less-than-impressive tea stain removal. It makes you wonder exactly what Reckitt Benckiser are doing with their laboratories... |
Post# 1050214 , Reply# 29   11/7/2019 at 19:28 (1,723 days old) by SudsMaster ![]() |
![]() It's been my impression over the years that chlorine bleach should not be used in Bosch dishwashers, due to the potential for corrosion of stainless steel from free chlorine. However my Bosch SHU43C user manual doesn't mention anything other than use a detergent designed for automatic dishwashers (no hand wash detergents).
Even so, I've never used chlorine in my Bosch and probably never will.
Bosch recommends using Finish Tabs, either Powerball or Quantum. The linked page says the Quantum product includes a bleach (oxygen). However, the Finish Powerball Max-in-One tabs I've been using contain sodium percarbonate, which is an oxygen bleach.
From Wikipedia:
"As an oxidizing agent, sodium percarbonate is an ingredient in a number of home and laundry cleaning products, including non-chlorine bleach products such as Oxyper, OxiClean, Tide laundry detergent,[1] and Vanish.[4]
"Many commercial products mix a percentage of sodium percarbonate with sodium carbonate. The average percentage of an "Oxy" product in the supermarket is 65% sodium percarbonate and 35% sodium carbonate. The "ultra boosters" seen on infomercials may contain as much as 80% sodium percarbonate. However, sodium percarbonate is less expensive in its pure form[citation needed] and can be adjusted to any percentage the user desires."
One note: the air gap for the drain line has a cap at the top of the sink. Periodically I check that cap; quite often it has some food debris that is flushed and gets caught in the cap. Simple enough to clear that out. If it gets too clogged the DW won't drain properly. And debris in there is not a sign of DW failure... the "large object filter" at the bottom of the dishwasher is designed to send medium to smaller particles down the drain. The problem is really the design of the air gap, I've modified it slightly to make it less prone to catch debris that the DW filer is designed to pass on through to the drain line, but it still happens. Oh well. It's no biggie to check it before each cycle. I might have to modify it again.
PS-Just checked on the chlorine/Bosch question again. Bosch does prohibit the use of chlorine bleach with its Axxis clothes washers. But it does not prohibit its use in its dishwashers. In fact, at least one Bosch page recommends using a chlorine bleach containing DW detergent if tea stains persist. So there.
CLICK HERE TO GO TO SudsMaster's LINK |
Post# 1050255 , Reply# 30   11/8/2019 at 03:01 (1,722 days old) by mrboilwash ![]() |
We`ve had stainless steel DWs for as long as I can think of. There have been rare exceptions but plastic tub DWs have always been considered shabby over here and the few that existed vanished sometime in the 1970s I think.
Our DW detergents were highly caustic, mostly water glass, phosphates and loads of chlorine until much milder enzyme based formulas appeared in the 1990s. The stainless interior usually coped well with the old detergents, it was the dishes that didn`t. Lots of terribly etched glasses, onglaze prints that washed away in no time, and our enameled pots and pans all had a rough surface. That`s my memories and I don`t miss the chlorine based detergents at all. |
Post# 1050780 , Reply# 35   11/12/2019 at 01:07 (1,718 days old) by IIIJohnnyMacIII (North Carolina)   |   | |
Just wanted to update that the Palmolive Eco has removed stains from my storage containers. The plastic straws are just too far gone. I even tried soaking them in 1/4 cup bleach and 1/2 gal of water. When that didn't work I tried straight bleach. That didn't even work. Hopefully now the Palmolive will be proactive and keep stains off before they start. I might give the Cascade + Oxi tabs a try in the future. But I'm pretty happy with Palmolive Eco right now.
Post# 1050785 , Reply# 36   11/12/2019 at 03:55 (1,718 days old) by askolover ![]() |
![]() 2
![]() Glad that worked well for you. My mother's been using it for years. I just bought some a couple of weeks ago to have on hand since I use chlorine based powdered detergent primarily. I just finished off my Cascade fryer boil out...didn't really care for it. Cascade gel with the power of Clorox has chlorine in it...the powdered version DOES NOT...it's oxygen bleach (which is misleading since it has the Clorox label on it). I really like this |
Post# 1050794 , Reply# 37   11/12/2019 at 07:31 (1,718 days old) by IIIJohnnyMacIII (North Carolina)   |   | |
Askolover,
Thanks. I will give the Cascade gel with power of Clorox a try as well. It says that my Walgreens carries it. I will say, without any enzymes the Palmolive Eco definitely rellies more on the power of the spray arms and the heat of the water to lossen debris. I would think this stuff would be perfect for those with KDS and Power Clean Whirlpools! |
Post# 1050859 , Reply# 38   11/13/2019 at 02:53 (1,717 days old) by askolover ![]() |
![]() 2
Post# 1050929 , Reply# 40   11/13/2019 at 20:51 (1,717 days old) by SudsMaster ![]() |
![]() Deborah,
Bosch specifically warns NOT to use chlorine bleach in its AXXIS front loader washer.
drive.google.com/file/d/0B8OAhHo...
On page 13, see the following:
"DO NOT use chlorine bleach in this washing machine."
While the manual doesn't explain why, I have read in past forum posts here or elsewhere, that it's because the chlorine bleach could damage the washer's heating element.
Post# 1050931 , Reply# 41   11/13/2019 at 20:57 (1,717 days old) by SudsMaster ![]() |
![]() Also, chlorine bleach can and has caused pitting corrosion of stainless steel. There's an interesting thread somewhere on the internet I read some years ago, in a craft brew site, of an instance where sterilizing stainless steel brewing containers with chlorine bleach resulted in such pitting corrosion to the point where the vessels no longer could hold pressure due to pinhole leaks.
What makes stainless steel rust-resistant is a protective chromium oxide layer that forms on exposure to air. This layer is what protects the steel from rusting. The problem with chlorine bleach is that it can remove or compromise the chromium oxide layer and allow corrosion of the steel to occur.
In the case of the brewing vessels, I recall that the theory was that the bleach solution was not thoroughly rinsed out, and allowed to remain. As the solution evaporated, droplets of it became more and more concentrated, to the point where the concentrated bleach attacked the protective chromium oxide layer and resulted in the pinhole leaks.
Post# 1050934 , Reply# 42   11/13/2019 at 21:08 (1,717 days old) by SudsMaster ![]() |
Post# 1050937 , Reply# 43   11/13/2019 at 21:14 (1,717 days old) by SudsMaster ![]() |
Post# 1050953 , Reply# 44   11/14/2019 at 02:15 (1,716 days old) by askolover ![]() |
Post# 1050958 , Reply# 45   11/14/2019 at 02:53 (1,716 days old) by henene4 ![]() |
Miele machines do have a bleaching setting, don't they? |
Post# 1050960 , Reply# 46   11/14/2019 at 03:15 (1,716 days old) by mrboilwash ![]() |
I`m wondering if Bosch`s warning against the use of chlorine might have more to do with the aluminum spider than the stainless steel parts.
As I said before stainless steel interior dish washers have always been the preferred design in the EU, long before chlorine free DW detergents came along. But those were also loaded with waterglass a corrosion inhibitor which liquid chlorine bleach does not contain. Maybe this made all the difference. |
Post# 1050967 , Reply# 48   11/14/2019 at 05:21 (1,716 days old) by Logixx ![]() |
Miele say in their Professional manuals:
Post# 1051058 , Reply# 49   11/14/2019 at 21:53 (1,716 days old) by SudsMaster ![]() |
![]() Great post, Alexander. It explains quite well the problem with chlorine and how to avoid it.
I was rummaging around my fish pond supplies the other day, and came across a tub of sodium thiosulfate. I used to mix up a concentration of that, and then use a metered siphon to add it to the make up water that runs into the pond from the tap every morning on a timer. However since a few years ago, the local water service changed from elemental chlorine to chloramine, the actual chlorine levels plummeted and I've been able to get by without any thiosulfate usage since. |
Post# 1051071 , Reply# 50   11/14/2019 at 23:52 (1,715 days old) by mark_wpduet (Lexington KY)   |   | |
in FL washers are super small. You're literally using a couple of tablespoons and by the time the washer fills, it gets diluted and rinsed away. It's not like full-strength bleach is just sitting on the stainless. I could totally see how that could eat away at anything. I've seen so many videos of failing spiders and the inner tub is caked with mutant funk...I think that's what kills the spider, not the bleach. I can't stress how I'm talking about a couple of tablespoons of bleach going in the dishwasher (give or take) at the very moment you start it. I'm not like pouring a whole cup in there or anything. I use so little of the stuff that 1/2 gallon takes me ages to go through and I can barely get through it before it expires.
My FL washer is approaching 15 years old & it would be very difficult for me to go live without a little LCB I remember growing up, we used Chlorox bleach in our TL washer, and we poured the recommended amount in and it was so STRONG. We always cut way back on the recommended amount because a little of it goes a LONG way and does less damage to fabrics. |
Post# 1051078 , Reply# 51   11/15/2019 at 02:01 (1,715 days old) by SudsMaster ![]() |
![]() Just as an aside... salt water can corrode stainless steel, from the chloride ion in salt, which is sodium chloride. The steels with more nickel, like 18-8 or 304, are more resistant to salt water corrosion. 18-8 mean 18% chromium, 8% nickel. Even more resistant to salt water is 316, which is 16% chromium, 10% nickel, and 2% molybdenum. The molybdenum gives it more salt resistance.
There are many different types of stainless steel. In broad categories, they might be ferritic (usually magnetic), martensitic (harder, like for knives), precipitation hardening, or austenitic (generally non magnetic unless worked). The 304 and 316 types are austenitic. Most stainless steel knives (for cutting) are martensitic. Most stainless cutlery is austenitic, with the better quality being 304 or 316. It's a complex subject and even two knives made from the same type steel may have different characteristics depending on how they are manufactured.
