Thread Number: 80915
My 1985 Maytag A712 Extra Capacity Washer Rebuilt |
Post# 1049479 , Reply# 1   10/30/2019 at 20:38 (1,639 days old) by scrubflex (bronx, new york)   |   | |
the cause of the leakage...destroyed tub bearing seal
Post# 1049500 , Reply# 3   10/30/2019 at 22:59 (1,639 days old) by scrubflex (bronx, new york)   |   | |
the tub nut was completely frozen and refused to give in...soaked it with WD-40 and Liquid Wrench 3 to 4 days...still would not budge...decided to buy a rotary metal cutter
Post# 1049501 , Reply# 4   10/30/2019 at 23:02 (1,639 days old) by scrubflex (bronx, new york)   |   | |
...learned that this is the best Liquid Wrench Rust Penetrating Oil Spray
Post# 1049502 , Reply# 5   10/30/2019 at 23:02 (1,639 days old) by eurekastar (Amarillo, Texas)   |   | |
Post# 1049503 , Reply# 6   10/30/2019 at 23:13 (1,639 days old) by scrubflex (bronx, new york)   |   | |
...decided to buy a rotary metal cutter, ordered it but, was damaged during the shipping and handling process---(isn't that weird)...was advised by one of the BEST person in the world Drew (redcarpetdrew) to cut it off...I brought a 5 pc. set of Cold Chisels
Post# 1049505 , Reply# 7   10/30/2019 at 23:21 (1,639 days old) by scrubflex (bronx, new york)   |   | |
my FIRST TIME repair eurekastar...it'd taken supernatural patience and assistance from above |
Post# 1049536 , Reply# 8   10/31/2019 at 08:50 (1,638 days old) by eurekastar (Amarillo, Texas)   |   | |
Post# 1049546 , Reply# 9   10/31/2019 at 11:16 (1,638 days old) by Combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Post# 1049552 , Reply# 10   10/31/2019 at 12:11 (1,638 days old) by redcarpetdrew (Fairfield, CA)   |   | |
I am humbled that you reached out for help and that my advice helped you. Like I reminded you. As you post your story of the washer that seemed bound and determined to not wash again, you stuck with it. You didn’t lose faith and tackled everything it threw at you like a 30 year vet of the field! Can’t wait to see the rest of the pics and the video of your born again 712.
RCD |
Post# 1049553 , Reply# 11   10/31/2019 at 12:22 (1,638 days old) by LowEfficiency (Iowa)   |   | |
>> ...after removing the clamp carefully keep the rubber gasket in position (measure to the bottom edge from >> gasket and above towards upper edge)...spacing needs to be correct for reinstalling the cover properly You might be better off following the Maytag or Repair-Master procedures for setting the top cover spacing when reinstalling. The reason being, when taking apart an old used appliance, you don't necessarily know for sure that whoever had it apart before you re-assembled it correctly. Measuring and duplicating that flawed work propagates (and sometimes exacerbates) any errors they might have made. The actual procedure for tub top cover alignment is pretty simple - either setting measured wood blocks on the top of the basket and pushing the top cover down on them to achieve a uniform spacing between the inner basket and the bottom of the tub top cover, or reinstalling the top of the machine cabinet and adjusting the top tub cover up or down to have the prescribed uniform clearance against the underside of the top cabinet opening. Either way gets you to the same result, and after doing it, is relatively painless. Good luck! |
Post# 1049658 , Reply# 12   11/1/2019 at 23:16 (1,637 days old) by potatochips ( )   |   | |
Ahh the 712. Makes me want to take mine out and use it as a daily driver. Damn Neptune is too good to give up for a while. |
Post# 1049712 , Reply# 14   11/2/2019 at 17:09 (1,636 days old) by scrubflex (bronx, new york)   |   | |
Finally was able to remove the inner washtub...I used multiple cleansing products to clean the parts as I remove them...also used rust-fighting products to address the rusting areas as I go |
Post# 1049721 , Reply# 15   11/2/2019 at 18:51 (1,636 days old) by statomatic (France)   |   | |
WD40 that helps removing a blocked nut is some kind of legend, if it really worked you didn't had to break it.
I've stopped using such thing five years ago, since then I've never broke any nut, bolt, screw... just need a longer wrench for more force, heating/freezing helps a lot too a it breaks the rust. |
Post# 1049725 , Reply# 17   11/2/2019 at 19:42 (1,636 days old) by scrubflex (bronx, new york)   |   | |
Wheww, that was tough, now cutting thru the stem skirt...ahh, it's done what a relief
Post# 1049726 , Reply# 18   11/2/2019 at 20:07 (1,636 days old) by scrubflex (bronx, new york)   |   | |
Removed outer tub, cleaned inside and out thoroughly, Brillo scrubbed and sanded all rusted areas of the tub...including the tub cover...used clamp position markings |
Post# 1049727 , Reply# 19   11/2/2019 at 20:15 (1,636 days old) by scrubflex (bronx, new york)   |   | |
the tub bearing seal dropped down the transmission shaft post
Post# 1049728 , Reply# 20   11/2/2019 at 20:31 (1,636 days old) by scrubflex (bronx, new york)   |   | |
outer tub sleeve bearing... |
Post# 1049729 , Reply# 21   11/2/2019 at 20:56 (1,636 days old) by scrubflex (bronx, new york)   |   | |
...even the sleeve bearing refused to cooperate...the chisel was called again to assist in the removal...piece by piece
Post# 1049730 , Reply# 22   11/2/2019 at 21:04 (1,636 days old) by scrubflex (bronx, new york)   |   | |
Post# 1049732 , Reply# 23   11/2/2019 at 21:13 (1,636 days old) by eurekastar (Amarillo, Texas)   |   | |
Post# 1049735 , Reply# 24   11/2/2019 at 21:53 (1,636 days old) by scrubflex (bronx, new york)   |   | |
cleaned up inside the cabinet...scrapped off detergent residue grit from leakage on the transmission shaft post...and cleaned up the transmission, shaft and post...pulled it out to install the damper pads |
Post# 1049753 , Reply# 26   11/3/2019 at 07:49 (1,635 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Yes old washers can be fun to take apart, overall the washers tubs etc look to be in pretty good shape, Have you located a replacement transmission yet, the agitator shaft is far too rusted for a long lasting repair in the water seal area.
There are still orbital transmissions around and then you can upgrade the washing and rinsing performance by using a Load-Sensor agitator and if you further upgrade by using a 50 cycle motor pulley and belts you will have a pretty decent performing washer.
Thanks for all the great step by step pictures of your rebuild this helps others save their vintage machines.
John L.
Post# 1049804 , Reply# 30   11/3/2019 at 17:14 (1,635 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
The top tub bearing should only have turbine oil used, lithium grease is too thick, the brake should have transmission oil in it only.
If you don't replace the transmission you are doing a lot of work for a washer that is only going to run a year or so at best till you have water leaking into the top spin bearing or into the transmission.
Post# 1049878 , Reply# 33   11/4/2019 at 07:08 (1,634 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
I would NOT put grease on the bottom OR top of the water seal, to install the seal to the tub use a little diluted liquid detergent and it will slide right into place.
No grease or other lubricants should be used on the carbon ring.
Putting a 2nd old style agitator seal under the new lip seal may push the lip seal out of place or the pressure from the bottom may quickly destroy its effectiveness,
Good luck, John L. |
Post# 1049889 , Reply# 34   11/4/2019 at 08:26 (1,634 days old) by swestoyz (Cedar Falls, IA)   |   | |
Harry - I commend your efforts on rehabilitating your Maytag. Sometimes you just need to dive in to get the job done, and having several here on the forum helping along the way isn't a bad thing at all. :)
I'll echo John's warning about adding oil to the stem seal. The newer Teflon style stem seal kit (both the A4298 version through 1996 and triple lip center seal version post August 1996) is not meant to have any lubrication added to "seat" the seal, instead Maytag recommends that the washer be set to spin for about 3 minutes or so after assembly to break in the seal. While access to the older style seals is limited these days Maytag went back and forth in the 80's on adding oil or not adding oil to the stem seal with a handful of design changes. When they did they recommended using the transmission oil (similar to a 60-70w gear oil) vs. center seal grease (similar to white lithium grease). Ben Screen shot below from the Jan 1992 Let's Talk Service)
Post# 1049917 , Reply# 35   11/4/2019 at 14:20 (1,634 days old) by scrubflex (bronx, new york)   |   | |
Thanks John L. and Ben, I actually followed that bit of information from a Maytag washer Appliance Repair Guy video on YouTube. (Should I remove the grease???) And, John L. please let me know if you come across a possible replacement...I'm looking |
Post# 1049922 , Reply# 36   11/4/2019 at 14:54 (1,634 days old) by swestoyz (Cedar Falls, IA)   |   | |
Post# 1049967 , Reply# 37   11/4/2019 at 20:00 (1,634 days old) by scrubflex (bronx, new york)   |   | |
Hey Ben, thanks again...oh the 712 has been operating going on two weeks or so...I think...I'm just sharing my journey...planning on post videos also |
Post# 1049974 , Reply# 38   11/4/2019 at 22:59 (1,634 days old) by redcarpetdrew (Fairfield, CA)   |   | |
When I replace the stem and boot on dc washers I usually install the old style centerpost seal as well. The only time I don’t is when there is the white clip on the top of the orbital trans. So far, I have not had any issues with it and the lip seal on the new stem is potentially iffy by itself. I’m definitely not trying to contradict you John by any means but this has worked for me on many, many repairs. I just don’t totally trust the new lip seal, esp if there is any slight defects to the trans shaft...
RCD |
Post# 1049975 , Reply# 39   11/4/2019 at 23:04 (1,634 days old) by redcarpetdrew (Fairfield, CA)   |   | |
Post# 1049980 , Reply# 42   11/5/2019 at 01:30 (1,634 days old) by scrubflex (bronx, new york)   |   | |
Lghh, thanks RCD, the victory is ours because you helped me every step of the way...thank you for your persistence...I am capable because of you...I can't wait to be able to build my dream machine washer |
Post# 1050027 , Reply# 45   11/5/2019 at 14:27 (1,633 days old) by scrubflex (bronx, new york)   |   | |
started her up...filling up nicely...spray fill works better...she's ALIVE!!!...look at her GO!!! CLICK HERE TO GO TO scrubflex's LINK |
Post# 1050028 , Reply# 46   11/5/2019 at 14:31 (1,633 days old) by scrubflex (bronx, new york)   |   | |
...here's a tub full of water...ahh, the powerful water surging of the Power-fin Agitator CLICK HERE TO GO TO scrubflex's LINK
Post# 1050031 , Reply# 47   11/5/2019 at 15:10 (1,633 days old) by scrubflex (bronx, new york)   |   | |
Let's see how she does with the first test load...looks GREAT. CLICK HERE TO GO TO scrubflex's LINK |
