Thread Number: 80923
/ Tag: Modern Dishwashers
Dishwasher with good drying performance? |
Post# 1049158 , Reply# 1   10/28/2019 at 14:56 (1,733 days old) by johnb300m (Chicago)   |   | |
![]() 2
Post# 1049166 , Reply# 2   10/28/2019 at 15:44 (1,733 days old) by Mrsalvo ![]() |
![]() 2
I bought a new MOL Maytag earlier this year and it dries everything. It washes well, though cycle times are a bit long-in-the-tooth. No filter to clean. Bought it on the recommendation of one of the members here, though I did see a GE I really liked. |
Post# 1049190 , Reply# 4   10/28/2019 at 19:13 (1,733 days old) by appnut ![]() |
![]() 2
![]() I have a 4 y/o Kenmore Elite that was made by Whirlpool's KitchenAid brand. It has an extra dry option. Dry cycle is 1.5 hours long and the little fan runs for an additional hour after the end of the cycle. Even disposable storage containers are dry except for little crevices on the edge. It's terrific. Comparable would be a Maytag with the Long Powerdry option or KitchenAid with ProDry system and Extended ProDry option on the control panel. |
Post# 1049618 , Reply# 6   11/1/2019 at 10:46 (1,729 days old) by DADoES ![]() |
Post# 1049623 , Reply# 7   11/1/2019 at 11:52 (1,729 days old) by johnb300m (Chicago)   |   | |
![]() 2
I hate “know nothing” articles like that.
First off, maybe 30% of the dw market has “air pump” drying? It’s a premium feature. Most use simple convection or sealed condensation drying like Bosch and KA. Second, dws with heating rods are designed that way and must withstand the heat by the heater. That’s why wash arms have shields. Heaters have thermal sensors. And tubs are made of durable materials often with a lifetime warranty. And with the lowering of heating wattage for energy conservation, there’s far less risk to dishes and plasticware than from the days of the old Plastisol GEs that destroyed anything plastic my mom put in the lower rack lol. What a garbage article. |
Post# 1050858 , Reply# 9   11/13/2019 at 02:36 (1,717 days old) by chachp ![]() |
You can also get a Bosch within your price range. Mine has an Extra Dry option and it dries really well. As mentioned above, rinse agent makes a difference. What I like about the Bosch (I don't know about the others mentioned here) is it has a flow through water heater. There is no exposed heating element in the bottom which means you can put plastic on the bottom AND the top without worry of melting anything. The Bosch doesn't use a fan to dry the dishes. I don't exactly understand how it all works without the fan but it does.
Like others have mentioned everything is dry except for those things that have the indents like in plastic container lids. I try to remember to load them so they drain but sometimes I forget. I think you'd be happy with one of these as well. |
Post# 1050951 , Reply# 10   11/14/2019 at 00:22 (1,716 days old) by SudsMaster ![]() |
![]() 4
![]() I'm always a bit mystified when people want perfectly dry dishes from an automatic dishwasher. It's no biggie to me to have a clean towel handy to dry off the bottoms of cups, bowls, and glasses that might collect a little water that doesn't "flash dry" in the Bosch dishwasher. I do this as I put the dishes away. I actually prefer it this way, because if the DW had a heated air blast to dry the dishes, mineral deposits would collect in areas of items that collect water. The clean towel mops them up along with the water.
Your mileage may vary ;-)
