Thread Number: 80978
Your ONE-SIDED Wash Loads |
Post# 1049762   11/3/2019 at 10:18 (1,727 days old) by DaveAMKrayoGuy (Oak Park, MI)   |   | |
Is there a way to prevent them?
Often the load is unbalanced and I can't always rescue my washer, thumping and banging from the beating it takes from an unbalanced load in time... And usually it's the OTHER SIDE of the tub the load of laundry is impaled against, so how funny it is to get a good shot of the entire load stopped against the side of the tub over HERE: -- Dave
Post# 1049763 , Reply# 1   11/3/2019 at 10:24 (1,727 days old) by kenwashesmonday ![]() |
![]() 7
Use the proper water level for the load.
Wash like-weighted fabrics together.
Wash full loads. |
Post# 1049766 , Reply# 2   11/3/2019 at 10:39 (1,727 days old) by appnut ![]() |
![]() 4
Post# 1049769 , Reply# 3   11/3/2019 at 10:47 (1,727 days old) by DaveAMKrayoGuy (Oak Park, MI)   |   | |
Yes, that neutral drain often begins with a groan, and I often coax the spin by opening the lid and closing to initiate or resume proper functioning...
Too much water for the load? Meet Mr. Paranoid about being sure all the soap gets rinsed out as he is doubtful unless he soaps a lot the clothes won’t get clean—and that thing about rollover: I watch like a hawk adding more water and ever fueling my bad laundry habits... — Dave |
Post# 1049774 , Reply# 4   11/3/2019 at 12:18 (1,727 days old) by combo52 ![]() |
![]() 5
![]() Stop forcing the washer to spin, let it drain the lint and dirt out of the clothing and let the clothing settle evenly in the basket, forcing a spin with water in the basket causes poor rinsing.
You should also wash larger loads and from the look of the crud stain on the agitator you need to use some combination of Hotter wash water, more or better detergent, if you are not dissolving and suspending all the dirt in the wash cycle it is IMPOSSIBLE to rinse clothing properly as the dirt and scum still remain in your clothing.
Hi Glenn, KM DD Washers like this do not have out of balance cut off switches., only a few Catalyst and TOL electronic DD KMWs had this cut out switch.
Post# 1049776 , Reply# 5   11/3/2019 at 13:10 (1,727 days old) by whatsername (Denver, CO)   |   | |
Post# 1049779 , Reply# 6   11/3/2019 at 13:36 (1,727 days old) by pierreandreply4 (St-Bruno de montarville (province of quebec) canada)   |   | |
Post# 1049785 , Reply# 7   11/3/2019 at 14:31 (1,727 days old) by imperial70 ![]() |
![]() 10
Your washing machine is filthy. |
Post# 1049792 , Reply# 8   11/3/2019 at 15:29 (1,727 days old) by ozzie908 ![]() |
It was due to rust in the water supply and an old hot water tank/heater I was at a friends who had not used his washer in a long while as always at work so me being me and there all day decided to wash some whites I have to say I was not impressed when everything came our a pale shade of orange....
Austin |
Post# 1049859 , Reply# 10   11/4/2019 at 00:27 (1,727 days old) by DaveAMKrayoGuy (Oak Park, MI)   |   | |
Okay, all of your pointers are appreciated and well-taken, so thank you all for your guidance and suggestions of each each way has been a positive way...
Now, off the top, the first step: Cleaning that dirty tub! I couldn’t find a small packet of Lemi-Shine that I had seen months ago and probably should have bought, but here is something although expensive, probably a lot better: Three packets, mandatory use of hot water, so question is how high of a water level should I go? How long should the timer be on, and I would reckon the fast agitation and fast spin would also be recommended... Let me know before I start... — Dave |
Post# 1049873 , Reply# 11   11/4/2019 at 06:29 (1,726 days old) by Yogitunes ![]() |
![]() 11
NO, NO, NO.....your machine lacks any sort of Self-Clean feature what-so-ever...
no high water level is going to fix that filthy of a machine....short of taking a power washer to the whole thing.... I cannot conceive of you being a member of AWO and allowing a machine to get that far gone.....Helen Keller knew it needed cleaned with more than just W-A-T-E-R!!! bottom line....ELBOW GREASE!!! your going to need a few things.....and dropping in a tablet and running away isn't one of them.....that is, IF, and thats a BIG IF your going to do it right!!! that cabinet needs to come off....the agitator needs to come out....the splash shield and balance ring need to come off for starters.... -Fantastic -409 -Purple Cleaner -Bathroom cleaner with Bleach a few cleaning cloths, toothbrush, and an assortment of scrubbers will be needed....it helps if they actually touch the surfaces... I have an idea....post a thread with pics of your progress in action.... in the end, you may have a machine that will CLEAN your clothes rather than make them dirtier then when they went in... |
Post# 1049879 , Reply# 12   11/4/2019 at 07:09 (1,726 days old) by DaveAMKrayoGuy (Oak Park, MI)   |   | |
Well, literally, you all just make me want to--THROW IN THE TOWEL!!!!
That much work to use a washer, and then after a lifetime of my mother just doing my laundry for me, and simply saying clothes get clean and a washer lasts by simply NOT overloading, hence carrying on tradition of her philosophy and nothing more, whereas all that hard labor you guys are capable of making second nature? Hmmmmm... -- Dave
Post# 1049883 , Reply# 14   11/4/2019 at 07:58 (1,726 days old) by mrboilwash ![]() |
Post# 1049888 , Reply# 15   11/4/2019 at 08:20 (1,726 days old) by DaveAMKrayoGuy (Oak Park, MI)   |   | |
Tub filled to the max, washin’ hot, agitatin’ ‘n spinnin’ fast!!!!
— Dave |
Post# 1050018 , Reply# 16   11/5/2019 at 12:29 (1,725 days old) by DaveAMKrayoGuy (Oak Park, MI)   |   | |
Okay, here is the nearly-full-sized load up to the water level’s maximum High, and even threw in a few of my clothes with what’s mostly the wife and mainly the kid’s stuff...
I quit using my Delicate wash cycle with the exception of a few whatever “dainty” things, we have around here, as my daughter’s friend has a dog, and her family is pet sitting a terrarium of gerbils, so I always wince and wrinkle my nose every time that I come over picking up/dropping my daughter off and she finally said that her clothes smell like her friend’s dog (& here she is wanting and begging us to buy her one, or some other pet like those gerbils, a rabbit or a hamster (but often a cat is tempting me)... Wash and Rinse with a good detergent, and even Drying, shown: — Dave |
Post# 1050019 , Reply# 17   11/5/2019 at 12:52 (1,725 days old) by DADoES ![]() |
![]() 6
Post# 1050132 , Reply# 18   11/7/2019 at 01:11 (1,724 days old) by DaveAMKrayoGuy (Oak Park, MI)   |   | |
Post# 1050156 , Reply# 19   11/7/2019 at 10:25 (1,723 days old) by DaveAMKrayoGuy (Oak Park, MI)   |   | |
Well, okay, here is a full load with a different detergent with the water level set where I’d left it, and this soap is cheap stuff from Walmart...
Also using warm water for the wash, mommy and baby’s stuff (which will be an Always) with “something” (Ahem!) added in... — Dave |
Post# 1050157 , Reply# 20   11/7/2019 at 10:36 (1,723 days old) by DaveAMKrayoGuy (Oak Park, MI)   |   | |
Post# 1050190 , Reply# 22   11/7/2019 at 17:08 (1,723 days old) by ozzie908 ![]() |
![]() 7
Post# 1050249 , Reply# 24   11/7/2019 at 23:47 (1,723 days old) by DaveAMKrayoGuy (Oak Park, MI)   |   | |
Then it's so ordered:
Anyway I've seem to have followed nearly all advice here, I have refrained from being near the machine at or during any of its draining periods, and no unbalanced loads, either... I think the laundry comes out satisfactorily but if not, then I will try the rag test that brisnat81 recommended... I think despite the results of using my washer cleaner being embarrassingly as the machine was before, I did okay, other than, perhaps I should have rubbed that dirty spot with a rag during that washing, then... So, thanks, then, and I will see if I can someday attempt to dismantle my entire unit and hopefully get her back together again and running as perfectly and better... -- Dave |
Post# 1050256 , Reply# 25   11/8/2019 at 04:29 (1,722 days old) by DADoES ![]() |
![]() 5
![]() Still more water than necessary. Your loads aren't as large as you think. Rapid, frantic rollover is overrated, with items spending mere seconds at a time at the oscillating lower fins, compared to a leisurely roll having the items spend a minute or even a couple down there before moving on up. The little load pictured above, the lowest level or a little more, maybe 9:00 to 9:30 position, is sufficient. Sun, Xtra, and other low-cost liquid detergents have a larger proportion of water in the formula ... adds volume and reduces the concentration of cleaning ingredients (lower production cost). Low-cost powders have a lot of washing soda (sodium carbonate) which can contribute to harsh-feeling fabric. These products also may have only one type of enzyme or none at all. Pinol Ensueno powder has no enzymes. - Sodium Sulfate (filler), a sodium salt of sulfuric acid - Sodium Alkylbenzene Sulfonate (cleaning agent), an anionic surfactant - Sodium Silicate (builder), composed of quartz sand and soda ash, aka water glass (soluble in water) - Sodium Carbonate (builder), an alkaline sodium and carbon salt, aka washing soda - Active Poly Sodium Metasilicate (builder), a non-phosphorus detergent/water softener - Fragrance - Disodium Distyrylbiphenyl Disulfonate (optical brightener), a dye that absorbs UV light and reflects blue light Does someone in the household have skin sensitivity such that you can't use enzyme detergents? Witness the gray scum-line on your agitator ... that's scrud (combination of laundry soil and mineral content from the water) that isn't held suspended in the wash water to be flushed away, and thus sticks to the agitator (and the basket) at the water line. This occurs with low-quality detergents (not handling the water conditions and soils), and too-low of detergent dosage can be a factor. What you see on the surface *may* (or may not) be much worse accumulation on the outside of the basket and inside of the outer tub, where it can't be seen without disassembly. Although that's not unusual for the typical washer. The outer tub is translucent so scrud/gray/black residue sticking to it can be seen if the outer cabinet is removed ... if you're up to doing that. Consider Arm & Hammer, All, Gain, and Tide Simply Clean (yellow bottle). Good Housekeeping 2019 Best Detergents If you want some extra rinsing without involving the full 2nd/Extra Rinse option, run the Perm Press cycle. It adds a partial-drain and refill for the cool down before the first spin, which also functions as a sort-of rinse. This is a perfectly fine leisurely rollover at low speed (not ex-low). Set of sheets plus a bedspread. Everything moves down, spends plenty time at the fins where the cleaning takes place. High speed of course would be more aggressive and/or the wash time could be longer at 14 or 16 mins instead of 12 mins, but not really necessary for the load. |
Post# 1050270 , Reply# 26   11/8/2019 at 07:51 (1,722 days old) by DaveAMKrayoGuy (Oak Park, MI)   |   | |
Yes, for what the “budget brands” I had bought such a slew of could forge into the usual competition of Tide vs. Gain, of which, one and one only, ferret out just one scent!
No, no detergent allergies, and as for water level, I will be continuously clueless where to set until I buy one of those fancy, new-fangled front loaders that just automatically set the right one for you... Now let’s go out washer shopping and bring back the days of the Westinghouse slant front, as in the 21st century (LG, Samsung, or Haier?) answer to... — Dave CLICK HERE TO GO TO DaveAMKrayoGuy's LINK |
Post# 1050641 , Reply# 27   11/11/2019 at 07:30 (1,719 days old) by DaveAMKrayoGuy (Oak Park, MI)   |   | |
Okay, need to bath linen and other miscellaneous towels? Can my little washer do all this:...?
Where should the water level be set at? I want the load to be good for washing it in, as well as good for itself... Operator is standing by... — Dave |
Post# 1050655 , Reply# 28   11/11/2019 at 09:30 (1,719 days old) by appnut ![]() |
Post# 1050661 , Reply# 29   11/11/2019 at 09:50 (1,719 days old) by combo52 ![]() |
![]() 5
Post# 1050676 , Reply# 30   11/11/2019 at 11:30 (1,719 days old) by DaveAMKrayoGuy (Oak Park, MI)   |   | |
![]() THREE loads: The huge green ones and the blue set, plus the smaller misc. stack...
Going on tonight... (Stay Tuned!)
-- Dave |
Post# 1050681 , Reply# 31   11/11/2019 at 11:56 (1,719 days old) by DADoES ![]() |
![]() 4
![]() Dave, your washer isn't as "little" as you seem to believe. There's no need to split that into three loads. Bit tricky to judge the size of those towels but this (white outline) probably constitutes a full load. That other little pile looks like kitchen linens? I'd put the dark piece(s) with the other piles and either 1) wait for more white kitchen stuff to accumulate, or 2) if the stuff is urgently needed, go ahead and do it (SMALLest load, which it's not even that), WITH bleach. The best way to get a consensus opinion on your load size / water level selection is take a video of the machine washing and post it to YouTube so we can SEE how it's operating.
Post# 1050687 , Reply# 32   11/11/2019 at 12:29 (1,719 days old) by mrboilwash ![]() |
![]() 2
Oh my...
It`s not that difficult to set the correct water level in a TL. First you drop your clothes loosely and unfolded into the tub. Then you press them down with your hands, but not too hard. Next you fill the washer at maximum load setting and keep a eye on the water level. As soon as your clothes are completely covered with water (or maybe an inch or two more for good measure) you slowly turn the water level selector towards the small size setting until filling stops. Now you have the perfect setting for your load size. You`ll learn and adapt quickly and soon you`ll find the perfect setting without any guesswork. Towels BTW are usually color fast and unless they are brand new or white there shouldn`t be any need to separate them by colors. |
Post# 1050688 , Reply# 33   11/11/2019 at 12:33 (1,719 days old) by eurekastar (Amarillo, Texas)   |   | |
![]() 2
Post# 1050703 , Reply# 34   11/11/2019 at 14:38 (1,719 days old) by kenwashesmonday ![]() |
That washer should be able to handle 8 large bath towels without breaking a sweat. |
Post# 1050707 , Reply# 35   11/11/2019 at 15:15 (1,719 days old) by thomasortega ![]() |
![]() 5
A steam cleaner there would make wonders. I don't understand why keep the washer so dirty after so many people mentioned it. If it was me, I'd immediately manicure it and post a picture of it pristine. I didn't really understand why (maybe you explained it before but I didn't have the chance to see it) but i'm sure you have a good reason to have all those writings and stickers on the control panel. |
Post# 1050799 , Reply# 36   11/12/2019 at 07:43 (1,718 days old) by DaveAMKrayoGuy (Oak Park, MI)   |   | |
Well, that small pile of clothes shouldn’t have gotten circled... Those are my wife’s and daughter’s that weren’t going to be included...
The washer filled and started agitating in no time, so I hope I’m getting this right... Okay, if I can find something to wash that agitator that will actually clean it and the rest of the surroundings and can take the time, then I will... So here are those two piles of bath linens I had to quickly do, as I have to work today, and want to get my work clothes done next: — Dave |
Post# 1050801 , Reply# 37   11/12/2019 at 07:53 (1,718 days old) by DaveAMKrayoGuy (Oak Park, MI)   |   | |
Oops, missed the Rinse! The load is actually done:
And that third pile of linen will go back in the basket and wait for more to accumulate... (Yes, the washer had to be a Kenmore (house came with) and if so, I wanted a LETTERS machine!) — Dave |
Post# 1050802 , Reply# 38   11/12/2019 at 07:58 (1,718 days old) by DaveAMKrayoGuy (Oak Park, MI)   |   | |
Work clothes, consisting of a company-logo’d polo shirt, long sleeve shirt to wear underneath it, apron, and a pair of jeans:
These are washed on the rarely-used Hang Dry (fast agitation, slow spin) and in Cold... And, it, too, started in no time! (Note new water level setting) — Dave |
Post# 1050808 , Reply# 39   11/12/2019 at 09:44 (1,718 days old) by DaveAMKrayoGuy (Oak Park, MI)   |   | |
Now a full load of my clothes (a vest I wear at work, a company-logo’d fleece) is also here:
[Edit: Rinse photos added] — Dave This post was last edited 11/12/2019 at 10:00 |
Post# 1050820 , Reply# 40   11/12/2019 at 13:19 (1,718 days old) by DADoES ![]() |
![]() 3
![]() Water levels are better. Load in Pic #38 can go all the way on Small. Avoid the Fast agitation speed for small loads unless they're very dirty and very sturdy fabric. Fast speed is very aggressive, which is what led to the infamous ShredMore nomer. Better results and less fabric wear with Slow agitation and a longer wash time. Slow/Fast is labeled as "Regular" for a reason. Your machine has a fully variable water level control. As Reply #32 details, you can get a handle on adjusting the level by setting it initially to a higher level than you think is needed. Press the items down *lightly* (don't stomp with your feet!). Start the machine filling and watch it. When the water reaches to the top of the load and a *little* more, turn the level control back toward small until agitation begins. Wondering why you're not using the ATC temp choices. You're in MI so tap water is presumably considerably cold this time of year ... which makes for the non-ATC 40% hot / 60% cold Warm temp being kinda cold. ATC should help moderate it from being too cold. Same for the ATC Cold setting, which will add some warm so the cold temp isn't too low for detergent to dissolve and be effective. |
Post# 1050840 , Reply# 41   11/12/2019 at 17:56 (1,718 days old) by DaveAMKrayoGuy (Oak Park, MI)   |   | |
Okay, so use the Auto Temp,—Check!
I forgot about the water level starting out High, then going Low... As for no longer using Fast Agitation, that will be something I will miss... I have an old bed spread with a matching pillow case that I quit using it on, but what about bath sets and rags? All of my laundry on Normal Agitation, then... Oh, to be mechanically inclined to tear my washer (& dryer—and OTHER APPLIANCES?!) open let alone devote the time—I hate doing yard work... — Dave |
Post# 1051426 , Reply# 42   11/17/2019 at 20:37 (1,713 days old) by DaveAMKrayoGuy (Oak Park, MI)   |   | |
![]() 2
Some more loads (wash and rinse) my washer has done:
And I probably still need to get the hang of where the water level's set... But of which, along with more laundry getting done at once, the washer survives, not in the least of which is the real great news: NO Unbalanced Loads!!!! -- Dave |
Post# 1051427 , Reply# 43   11/17/2019 at 20:39 (1,713 days old) by DaveAMKrayoGuy (Oak Park, MI)   |   | |
Ditto:
The clothes (w/ some help from my dryer sheets) do look and smell clean! — Dave |
Post# 1059357 , Reply# 44   2/1/2020 at 09:36 (1,637 days old) by DaveAMKrayoGuy (Oak Park, MI)   |   | |
Perfectly loaded in the washer at AMKrayoLaundryLand:
— Dave |
Post# 1059376 , Reply# 46   2/1/2020 at 13:08 (1,637 days old) by Yogitunes ![]() |
![]() 8
there should be a SPCA for washing machines....this is like a commercial for neglected appliances...
that machine would choke if HOT was selected.... as usually posted in SS....."Somebody should save that machine!".... no point in cleaning the machine now, chances are, the grime is what's holding it together! |
Post# 1059380 , Reply# 47   2/1/2020 at 14:09 (1,637 days old) by DADoES ![]() |
Post# 1059386 , Reply# 48   2/1/2020 at 15:50 (1,637 days old) by nmassman44 (Brooksville Florida)   |   | |
![]() 11
As much as I don’t want to be that person that points out what others have here....if the washer is that filthy, imagine what the rest of the house is like. I wouldn’t let a washer get that cruddy and then take a picture of said machine....I would be embarrassed to say the least....but that’s just moi....
Post# 1059466 , Reply# 49   2/2/2020 at 18:04 (1,636 days old) by DaveAMKrayoGuy (Oak Park, MI)   |   | |
Yes, I’m getting the hang of how much (how LITTLE really) water to use—if only you could see a load of pajamas I did after, actually waiting to go in the dryer I could just do a 2nd Rinse for...
In turn I would like and hope to see my water bill go down... Unfortunately we are not the greatest house cleaners, so I surely long needed to have gotten someone hired to do for me, or at least taken up with someone who’d long beaten me at the washer use and CARE given it’s only USE (& ABUSES ) that I can do... — Dave |
