Thread Number: 80994
/ Tag: Modern Dishwashers
BOSCH 800 Series throwing error code E:09 |
Post# 1049926   11/4/2019 at 15:05 (1,726 days old) by chachp ![]() |
So disappointed.....After only 18 months our Bosch dishwasher is throwing an error code indicating the heating element or heat pump is not working. The error indicates the water is not reaching full temperature and the dishes are really wet at the end of the cycle.
Online is says it could be because I'm not using the dishwasher correctly. So WTF is that supposed to mean? I dirty dishes, I put them in, I put soap in and press the button. What the XXXX am I doing wrong? LOL.
They are coming out tomorrow we'll see how that goes. Luckly I have a home warranty or this wouldn't be covered and I would be really pissed after such a short time. |
Post# 1049982 , Reply# 2   11/5/2019 at 01:49 (1,725 days old) by chachp ![]() |
This model does not have the water softener. We didn't get that model because we have a whole house water softener system. Your comment about the sudsiest water makes me wonder if that could have something to do with it. I use a Cascade pod in the main wash and a little bit of Cascade Powder in the pre wash. Maybe a tablespoon or so. I've never seen any sudsing in the bottom of the machine.
Is it possible the Cascade pods are too much given I have soft water? Could they be designed for harder water and should I be using only powder to better control the amount of soap?
We have a home warranty that covers the repair for the cost of a copay so I'll let them deal with it. I did see the YouTube video where they replace it from the side. While I have little fear working on vintage machines this looks like I could easily mess something up so I'll let them do it. As much as I like this dishwasher if this becomes a recurring issue she's out the door. |
Post# 1049990 , Reply# 3   11/5/2019 at 03:55 (1,725 days old) by henene4 ![]() |
There's really no need for that. Don't think it makes much of a difference fault wise, but I don't think you need that especially since this model should do soil sensing and you could end up without a prewash. |
Post# 1050047 , Reply# 4   11/5/2019 at 19:42 (1,724 days old) by combo52 ![]() |
![]() 2
![]() Be very careful with a home warranty company unless they are sending out an authorized Bosch service company, some parts of your DW are still covered by Bosch.
Home warranty companies have the worst techs working for them, a major consumer group here in Washington DC did a major report on HWCs and not a single service company that works with them was better than average with most being at the bottom of ratings.
Who ever shows up to look at this problem should be equipped with service information from Bosch and or a lap-top that can directly get such information from Bosch.
This is a complicated and often troublesome DW and it needs proper repairs if it is to last very long.
You should also check with your credit card company if this DW was purchased with a CC, as many CC companies will double the manufactures warranty period.
It is always a good to put at least some detergent in the first water change to help emulsify the food soils, this is the direst water change in a DWs cycle and it is asking for problems to skip the detergent.
Post# 1050387 , Reply# 8   11/9/2019 at 08:08 (1,721 days old) by chachp ![]() |
So here are my assumptions:
Has anyone else gone away from the pods because of soft water and if so, which brands? So many questions, I don't want to burn out another heat pump if I can avoid it. |
Post# 1050485 , Reply# 9   11/10/2019 at 05:04 (1,720 days old) by foraloysius ![]() |
![]() 2
I use a bit of powder in the pre-rinse. It does make a difference on the loads I do. I don't pre-rinse, only scrape. And I use the dishwasher only once in 2-3 days. Without a little extra powder things get clean alright, but when I add it, there is a noticeable difference. It's clean vs clean+.
I use Sun products at the moment, made by Unilever. Tabs for the mainwash and a little powder for the pre-rinse. |
Post# 1050491 , Reply# 10   11/10/2019 at 07:20 (1,720 days old) by chachp ![]() |
Thanks Louis. I started using a little extra powder for a pre wash at John L.'s suggestion a few months ago and I, too, notice a difference especially in how often I have to clean that filter. I also noticed that I can use the Speed60 cycle with the Extra Dry button and get really good results while cutting an hour off the cycle time. |
Post# 1050516 , Reply# 11   11/10/2019 at 11:55 (1,720 days old) by henene4 ![]() |
As far as I am aware, Speed60 does not run a prewash. If I'm not mistaken... |
Post# 1050520 , Reply# 12   11/10/2019 at 12:37 (1,720 days old) by chachp ![]() |
