Thread Number: 81040
/ Tag: Refrigerators
GE Combination Wall-Mount Fridge repairs... |
Post# 1050397 , Reply# 2   11/9/2019 at 10:47 (1,641 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Wow David it looks like you will have this refrigerator running soon.
Some thoughts The condenser set up is original, GE used a coiled condenser near the fan and the smaller tube and wire condenser behind the compressor. Do you think the compressor has ever been changed to the newer improved design ? To test the compressor GE suggests seeing how much vacuum it can pull, it should be very close to 30" other wise it is worn out. If you have to change the compressor I would adapt a modern compressor as the originals ran pretty hot and used a lot of power. If anyone needs it I have a NIB compressor and complete evaporator and heat exchanger for one of these wall refs that I would sell. John L. |
Post# 1050402 , Reply# 3   11/9/2019 at 11:29 (1,641 days old) by Repairguy (Danbury, Texas)   |   | |
Post# 1050409 , Reply# 4   11/9/2019 at 12:16 (1,640 days old) by pulltostart (Mobile, AL)   |   | |
Your talent, skills and patience are just awesome! I don't know beans about what you're doing, but your videos are so interesting I can't help but watch and listen. Sarah is soooo fortunate to have access to you and your shop to bring her refrigerator back to life. Makes me really wish that I could have used you about 10 years ago when my 1958 GE Combination bit the dust.
lawrence
Post# 1050425 , Reply# 5   11/9/2019 at 16:56 (1,640 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Good news David the compressor and condenser assembly in the ref is the official GE replacement Hi-Side, the condensers are correct and hopefully the compressor is still good. It looks a little crude the way a bracket was welded to the top of the compressor because this was a low production replacement part from GE.
Attached pictures of a complete Hi-Side replacement compressor that I have NIB. John L. |
Post# 1050444 , Reply# 6   11/9/2019 at 18:17 (1,640 days old) by sarahperdue (Alabama)   |   | |
Post# 1050486 , Reply# 8   11/10/2019 at 05:52 (1,640 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Post# 1050505 , Reply# 9   11/10/2019 at 09:43 (1,640 days old) by pulltostart (Mobile, AL)   |   | |
Those "cabinettes" were designed to be installed under standard, 12" deep wall cabinets. However, they could also be installed under this wall-mount refrigerator. In the case of the later, the cabinettes would be installed against the wall, flush with the rear of the refrigerator. I don't know if they were anchored to the wall (behind) or the refrigerator (above). If to the refrigerator, the mounting holes would be located in the rear half of the underside of the refrigerator, not the front half.
lawrence |
Post# 1050510 , Reply# 11   11/10/2019 at 10:28 (1,640 days old) by turbokinetic (Northport, Alabama USA)   |   | |
Reply#9 Thank you Lawrence. I appreciate this! I've been working to get the fridge and cabinet ready for painting before I go back out of town for work, and have focused on technical repairs. Need to investigate how it mounts so that if any fabrication is necessary it can be done before painting. |
Post# 1050533 , Reply# 13   11/10/2019 at 15:03 (1,639 days old) by sarahperdue (Alabama)   |   | |
David, thank you for working on this fridge. I'm enjoying your pictures, videos and explanations.
Yes, the cabinettes have sliding glass doors. All four are intact. I have them here and have been polishing the handles which were very corroded. I believe they are chrome plated steel, but even with very conservative abrasives--600 then 1000 and 1200 grit sandpapers--it looks like I'm removing the chrome because the corrosion was so bad. I'm going to polish all four down to the steel and wax them. Lawrence, the cabinettes will have to go under my fridge. It's a small kitchen, and the fridge is the only continuous run of upper cabinets that they will fit under. If they don't work well under the fridge, I'm not sure what I will do with them. Over the kitchen sink? I've got most of the interior parts except for the doors to vegetable compartments in the fresh food section. It looks like it needs four--similar to the butter conditioner doors in design but bigger. Sarah |
Post# 1050539 , Reply# 14   11/10/2019 at 15:28 (1,639 days old) by sarahperdue (Alabama)   |   | |
I just found a picture of a cabinette in good condition with glass doors.
Sarah
Post# 1050553 , Reply# 15   11/10/2019 at 16:33 (1,639 days old) by pulltostart (Mobile, AL)   |   | |
Another period photograph showing a kitchen with cabinettes in place.
lawrence
Post# 1050554 , Reply# 16   11/10/2019 at 16:34 (1,639 days old) by spacepig (Floridas Emerald Coast)   |   | |
I have 6 of these in pink. They are all either 24" or 21" inches long. All have the original glass except one. Here's a picture of some of them from the kitchen they came out of in Biloxi. I ended up buying most of these cabinets.
Post# 1050560 , Reply# 17   11/10/2019 at 17:16 (1,639 days old) by sarahperdue (Alabama)   |   | |
Lawrence and Jeannine
I don't have a long enough run of upper cabinets to put them anywhere but under the fridge. Lawrence, I am planning a peninsula and like the way they look in the left side of your picture, but I don't think my peninsula is long enough. Also, it's going to be standard cabinet depth with a cooktop on it. It looks like the footprint of the cabinettes is too wide to permit installation of both the cooktop and cabinettes on the same counter. Do either of you know what the bottom width of the cabinettes is? Mine is at David's. If I know the bottom measurement, I might be able to play around a bit with my plan. Thanks. Sarah |
Post# 1050564 , Reply# 18   11/10/2019 at 18:03 (1,639 days old) by pulltostart (Mobile, AL)   |   | |
Checking my 1957 catalog and finding -
Standard Cabinettes were 11-7/8" tall, 10-1/2" deep at the top, and 7" deep at the base. They were available in lengths of 21", 24", 30" and 36".
GE offered a special cabinette designed for installation under the wall refrigerator. It was 8" tall, 15-3/16" deep at the top, 13-3/8" deep at the base, and 64" long; so deeper front-to-back and shorter than the standard ones
lawrence |
Post# 1050568 , Reply# 19   11/10/2019 at 18:33 (1,639 days old) by ken (NYS)   |   | |
Post# 1050609 , Reply# 20   11/10/2019 at 22:26 (1,639 days old) by sarahperdue (Alabama)   |   | |
Thanks, Lawrence, mine was probably made for the fridge then. If it's not exactly as long as the fridge, it's very close and significantly longer than any of the others.
Re-chroming? I never think of that. I wonder if there's a shop in my area that does it. These have plastic grab thingies. I don't know if they'd be good candidates for chrome plating or not. Thanks, Sarah |
Post# 1050618 , Reply# 22   11/10/2019 at 23:17 (1,639 days old) by sarahperdue (Alabama)   |   | |
That's looking great, David.
I'm looking at the pictures I took of the cabinette before I left it with you. It looks like two cabinettes joined in the middle and faced with a single light unit. Here are pictures for the rest of you who haven't seen all of it. Alas, I had already removed the glass by the time I took the pictures. Sarah |
Post# 1050623 , Reply# 23   11/11/2019 at 00:27 (1,639 days old) by RP2813 (Sannazay)   |   | |
Post# 1050645 , Reply# 24   11/11/2019 at 07:57 (1,639 days old) by turbokinetic (Northport, Alabama USA)   |   | |
Sadly, I don't know of a re-chrome shop. I've been considering getting the hardware for my 1926 Frigidaire M52 replated as well; so hope to learn together! |
Post# 1052973 , Reply# 27   12/2/2019 at 21:58 (1,617 days old) by turbokinetic (Northport, Alabama USA)   |   | |
Today I took the doors off, condensing unit out, and dismantled the doors. This is at the paint shop now!
I got quite a few looks on the highway with this. LOL
Post# 1053004 , Reply# 28   12/3/2019 at 08:29 (1,617 days old) by ozzie908 (Lincoln UK)   |   | |
I dunno about anyone else but I can't wait to see the finished fridge I bet its going to look amazing..
Sarah I think it will last you many a year now its had David repairing it !! I have to watch his videos as they are mesmerising and I have learnt so much from watching this very talented man. Austin |
Post# 1058338 , Reply# 30   1/21/2020 at 23:19 (1,567 days old) by Repairguy (Danbury, Texas)   |   | |
Post# 1058362 , Reply# 31   1/22/2020 at 08:03 (1,567 days old) by ken (NYS)   |   | |
Post# 1058384 , Reply# 33   1/22/2020 at 12:58 (1,566 days old) by sarahperdue (Alabama)   |   | |
Post# 1058450 , Reply# 34   1/22/2020 at 21:35 (1,566 days old) by turbokinetic (Northport, Alabama USA)   |   | |
Sarah, it was fun visiting with a fellow vintage appliance enthusiast today! Good to see the door liner repairs moving along; and happy to have the Cabinette back on for a test fit. |
Post# 1059272 , Reply# 35   1/31/2020 at 08:26 (1,558 days old) by ozzie908 (Lincoln UK)   |   | |
Post# 1059290 , Reply# 36   1/31/2020 at 13:59 (1,557 days old) by pulltostart (Mobile, AL)   |   | |
Post# 1059299 , Reply# 37   1/31/2020 at 16:26 (1,557 days old) by sfh074 ( )   |   | |
Yes, the living room, or a room all to itself! |
Post# 1059328 , Reply# 39   1/31/2020 at 21:46 (1,557 days old) by sarahperdue (Alabama)   |   | |
Post# 1059344 , Reply# 40   2/1/2020 at 05:42 (1,557 days old) by sfh074 ( )   |   | |
the new door gaskets! Awesome finishing touch. |
Post# 1059462 , Reply# 41   2/2/2020 at 17:39 (1,555 days old) by sfh074 ( )   |   | |
had to post to this thread since it had the wall fridge and in same color.
Post# 1059475 , Reply# 42   2/2/2020 at 21:20 (1,555 days old) by turbokinetic (Northport, Alabama USA)   |   | |
Very cool picture! I love the GE appliances of course; but also the large windows, high ceiling, and openness. This is such a nice layout. |
Post# 1059718 , Reply# 43   2/6/2020 at 03:24 (1,552 days old) by askolover (South of Nash Vegas, TN)   |   | |
Post# 1059732 , Reply# 44   2/6/2020 at 06:56 (1,552 days old) by turquoisedude (.)   |   | |
