Thread Number: 81196
/ Tag: Modern Dryers
help to stack a dryer in top of a washing machine |
Post# 1052168   11/24/2019 at 14:40 (1,706 days old) by AEGboy70780 (Navarre,Spain)   |   | |
hello friends, sorry for being inactive, but i had some exams
as i said, im getting a beko heatpump dryer on christmas for the good price of 364€ (cheap for a heatpump dryer of a 5 star rated brand, meanwhile bosch dryers are 1k € and dont dry well and tangle everything now we have 2 slightly small problems 1 on the laundry room i have only one socket 2 due the laundry room being so small i am going to have to stack them and this is where the problem comes delievery is 20€ but you need "a stacking kit" that is a piece of plastic that costs 40€, and no, im not paying such a rip off for a piece of plastic (price would go up to 404€ and nope) is there any form of stacking both appliances without a stacking kit? btw for the socket im finding an electrician, as the one who did the installation for the old owners of the house the f****** dumba** didnt connected the main ground wire of the kitchen to the main ground connection of the house (and thats illegal) im not very fussed about power consumption as heatpump dryers are known for low power consumption (beko uses only 900W and my AEG uses 2150W, both together use 3050W and the current an EU socket line supports is 16A or 3500W) anyway, thats the job for the electrician hope the delievery dont take too long, as winters here are so cold (2ºC outside at the moment and im drying clothes on the hanger)and drying clothes now its a nightmare (plus towels after 95ºC wash and line dry feel like sandpaper :( and here there are some pics of it :) |
Post# 1052192 , Reply# 1   11/24/2019 at 18:34 (1,706 days old) by Yogitunes ![]() |
Post# 1052193 , Reply# 2   11/24/2019 at 18:42 (1,706 days old) by thomasortega ![]() |
I'd definitely go for the stacking kit. It's not just "a piece of plastic". It may look ridiculously simple but you can be sure it had the manufacturer's designers and engineers dimensioning it and making all sorts of calculations and testing to be sure it will keep the dryer safe even if someday the washer decides to jump. |
Post# 1052195 , Reply# 3   11/24/2019 at 18:48 (1,706 days old) by bradfordwhite (central U.S.)   |   | |
As Yogi said...
I'd build a shelf that attaches to the wall. I'd make the bottom of the shelf at least an inch / 3 CM higher than the height of the washer. This way you can put the dryer on the shelf and be able to move the washer in and out if you need to without disturbing the dryer. Also, the dryer is less likely to shake when the washer is spinning. Good luck |
Post# 1052241 , Reply# 4   11/25/2019 at 03:54 (1,705 days old) by chestermikeuk ![]() |
![]() 3
Weve got a Beko heatpump standing on top of an Ebac washing machine, similar to a Bosch in size & weight, the dryer has not moved an inch, its heavy and the rubber feet grip the washer worktop. A thin rubber mat sat under the dryer atop the washer may further help. Its never moved even during unbalanced spin, the dryer weight actually keeps the washer in check !!
Post# 1052276 , Reply# 6   11/25/2019 at 13:38 (1,705 days old) by foraloysius ![]() |
There are universal stacking kits available here in the NL, the cheapest one I added a picture of. Overhere the price is 15 euros. Don't know if they are available in Spain. What I don't like about them is that they use double sided tape to keep things in place. Other options are avaiable (for instance with a pull out shelf), but are more expensive.
Post# 1052282 , Reply# 7   11/25/2019 at 14:54 (1,705 days old) by Logixx ![]() |
Post# 1052343 , Reply# 8   11/26/2019 at 06:56 (1,704 days old) by foraloysius ![]() |
Post# 1070483 , Reply# 10   5/2/2020 at 14:37 (1,546 days old) by Aegboy70780 (Navarre,Spain)   |   | |
Post# 1070509 , Reply# 11   5/2/2020 at 17:21 (1,546 days old) by beehiveboy ![]() |
Post# 1071951 , Reply# 12   5/11/2020 at 11:10 (1,537 days old) by SudsMaster ![]() |
