Thread Number: 81255
/ Tag: Modern Dryers
HELP: 1-yr old SQ gas TR7 doesn’t dry on timed dry (though it fires fine) |
Post# 1052760 , Reply# 1   11/30/2019 at 09:32 (1,700 days old) by combo52 ![]() |
![]() 2
Post# 1053066 , Reply# 3   12/3/2019 at 18:58 (1,697 days old) by combo52 ![]() |
![]() Hi Mike, This problem should be easy to figure out if you give me more information.
How long would the same load take to dry on the sensor setting that you said takes 3 60 minute cycles on timed dry?
Take the lower panel off and watch the burner operation, If you put a 10 # or larger load of heavy cotton towels etc and set the dryer for 60 minutes the burner should not cycle off once in less than 30 minutes and probably longer.
If it does cycle off much sooner especially in less than 15 minutes, disconnect the vent from the back of the dryer and see if the burner runs any longer.
Did this dryer work fine on timed dry and suddenly stop correctly on timed dry ?
Post# 1053200 , Reply# 4   12/5/2019 at 05:32 (1,695 days old) by Mikel (NJ)   |   | |
Thank you John. Did this dryer work fine on timed dry and suddenly stop correctly on timed dry ? ^That is correct. |
Post# 1053202 , Reply# 5   12/5/2019 at 06:01 (1,695 days old) by DADoES ![]() |
![]() That's very odd. The only effective difference between timed dry and sensor dry, of course, is that timed dry runs for the selected number of minutes vs. sensor dry "time" controlled according to the sensor readings and programmed algorithms. The rest of the machine, unless there's something different about SQ, operates identically ... drum rotation, airflow, heating source, temperature control. Assuming that any given load does dry fully when run on a sensor cycle, how long does it take to finish? |
Post# 1053699 , Reply# 7   12/9/2019 at 16:30 (1,691 days old) by super32 ![]() |
Post# 1055849 , Reply# 8   12/28/2019 at 23:13 (1,672 days old) by Toggleswitch (New York City, NY)   |   | |
Are you using natural gas or propane?
If your gas is bottled gas / liquified propane/ propane, it is important to be sure the machine's burner has been properly converted for such gas. A natural gas dryer using propane has a HUGE flame and the burner will cycle on and off VERY rapidly. Carbon buildup and yellow/orange LIGHT will come out of the machine. Obviously, also a fire hazard to run a gas dryer with the "wrong" gas getting to the burner /orifice/regulator. Perhaps this accounts for the whacky drying.... Good luck! |
Post# 1055893 , Reply# 9   12/29/2019 at 15:15 (1,671 days old) by RP2813 ![]() |
Post# 1055899 , Reply# 10   12/29/2019 at 15:30 (1,671 days old) by DADoES ![]() |
![]() 2
