Any interest in a KDD-67 Deluxe Portable? Offers? I'm thinking it's around 1973 vintage, white enamel and chrome. I've been using it since 2004. Good washer, runs a wash in 20 minutes. Pick up in Belleville, Ontario.
A few quirks:
-I installed new hoses because a few of the ball bearings on the original tap adapter got lost and nobody had them. Comes with original hoses as well, all good condition.
-bi-metal strip in detergent dispenser corroded off so pump doesn't run during the wash fill cycle - I take this as my cue to add the soap.
-screen corroded off the rinse agent dispenser years ago when I used vinegar in it... started using JetDry instead, seems to work fine.
-some corrosion on the racks but not too serious
-timer doesn't advance after the wash cycle - needs to be manually advanced into the heated air dry part, I usually just open the door a bit and unplug it to air dry when the pump stops.
Does a great job, I'd keep it but it's a small house and I installed a built-in last month.
