Thread Number: 81312
/ Tag: Vintage Dryers
Fixing kdg606 |
Post# 1053393 , Reply# 1   12/6/2019 at 22:22 (1,603 days old) by JJoinoho (Ohio)   |   | |
Thanks I should have looked around the site more before posting. I found all the information here. |
Post# 1053639 , Reply# 2   12/8/2019 at 22:15 (1,601 days old) by Maytag85 (Sean A806)   |   | |
I actually have the same dryer but I converted my Maytag KDG606 to a DG306 since the electronic dry control wasn’t working properly and I didn’t feel like going through the trouble to fix it so I just put a 306 timer in it. I have no issues with mine at all but there are a couple of rattles I need to fix and once those are all fixed it would be very quiet in operation once all the rattles are fixed.
Post# 1053889 , Reply# 3   12/10/2019 at 22:59 (1,598 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
The thermostats will not cause it to shut off too soon, one thermostat is the cool down thermostat and it is normally open if it is under about 120F. The other is an operating TS and cycles the heat on and off around 145F and the safety TS cuts off the heat at around 180F.
There are many reasons that these dyers may not cut off properly, hopefully you have found the many great posts about these dryers that will help you find and fix the cause of the problem.
Post# 1053959 , Reply# 4   12/11/2019 at 11:51 (1,598 days old) by Maytag85 (Sean A806)   |   | |
In the thread about the Maytag A606 and KDG606 I acquired back in March, AW user QSD-DAN did say he had a couple of gas HOH dryers come through and he said everyone had a weak hi limit thermostat that would cycle it below the operating thermostat, and the only conclusion he came up with was the constant burning pilot lights play a role in weakening the bimetallic metal inside the thermostat.
Another thing too is if the belts aren’t adjusted properly it can cause the high limit thermostat to heat up since not enough air is getting pulled through the burner causing it to kick off the burner until it cools off. |
