Thread Number: 81367
Farewell Maytag Neptune |
Post# 1053997   12/11/2019 at 18:45 (1,689 days old) by panasonicvac (Northern Utah)   |   | |
Hi there everyone, happy holidays to you all!
Well, I was gone on vacation for overnight. I came back the next day with this in our laundry room. Apparently our Neptune washer has gotten louder and louder everytime it would go in the spin cycle. My dad had someone come over a week or two ago without me knowing about it yo look at it. The repair tech said that the bearing inside the washer is going out and there was no way that he could've fixed it. Even if he did had the part for it, it would've cost just as much as buying a new front loader washer. We went with an LG because just like our LG dryer, they were the brands to repair the least according to the tech. Anyways they had this delivered today and all hooked up. Now my dad is thinking about replacing the dryer with the matching set, shat do you guys think? Should we keep the dryer or replace it with the matching set? The washer is a model WM8100HVA and the dryer is a model DLEX5170W.
Post# 1053998 , Reply# 1   12/11/2019 at 18:50 (1,689 days old) by panasonicvac (Northern Utah)   |   | |
Post# 1054001 , Reply# 2   12/11/2019 at 18:59 (1,689 days old) by combo52 ![]() |
![]() 5
![]() Keep The dryer, it is easier to use with the rear controls and China already has enough of your money, there is absolutely no reason washers+ dryers need to match to have a great laundry.
Stoves, refrigerators and DWs never match, nor do furnaces and water heaters which are often installed SXS.
Let us know how you like the new washer compared to the old Neptune, Which Neptune did you have ?
Post# 1054007 , Reply# 3   12/11/2019 at 19:49 (1,689 days old) by panasonicvac (Northern Utah)   |   | |
Hi John,
I believe it was a model MAH7500AWW, it was one of those models where it had a touch screen control. I know I showed ours here not too long ago. Had I would've known it was getting replaced sooner, I would've written down what it was. I will definetly let you all know how we are liking the new washer, right now we are just kind of playing around with it so it may take us a few weeks or so. |
Post# 1054013 , Reply# 4   12/11/2019 at 21:05 (1,689 days old) by MaytagNeptune (FireAlarmTechGuy4444 on YouTube. Interlochen MI)   |   | |
![]() 3
Post# 1055531 , Reply# 5   12/25/2019 at 16:44 (1,675 days old) by panasonicvac (Northern Utah)   |   | |
![]() 2
Hope everyone is all having a nice holiday so far. So after some consideration, we're going to get the matching dryer to match with the washer for a good reason. My sister's dryer has been having problems recently and we're going to give her our other LG as part of her Christmas present.
So far we really like using the new washer, but I feel that it's going to take a little while longer until I would give a full review of it because there's still some other things I haven't washed yet that I would like to try out. It'll be up eventually, as well as a review of the new dryer. |
Post# 1055557 , Reply# 6   12/25/2019 at 20:43 (1,675 days old) by bradfordwhite (central U.S.)   |   | |
![]() Washer looks nice. FL wash better than TL tests have shown. My experience has also shown that.
I like the laundry area there with the floor drain. It looks like where the appliances sit it's a hard surface, but the rest of the room is carpeted. Is the floor pitched toward the drain? Is that a curb around the perimeter to keep water from leaking out of that area?
Love your Central Vac videos too.
Happy Holidays to you, and everyone here at AW. |
Post# 1056281 , Reply# 7   1/2/2020 at 14:16 (1,667 days old) by panasonicvac (Northern Utah)   |   | |
![]() 2
Had it installed this morning and just gave it a test run. So far it's working good! Just need to play around with how where going to have the dryer vent hose set up so that it's not sticking out like in this photo here.
Thanks Keith! From what I see, the floor seems completley flat. There is a curb that would prevent water from coming out of the hard surface. We've never had any major leaks from any of our washers before which is good. However though we did had a clog in that drain once before from all the dryer lint that was built up in there since we have a sink in the laundry room where it would also drain down in the same pipe as the floor drain. I think there's probably no doubt that FL washes better than TL. But I think when it comes down to FL compare to TL washers, I guess it would depend on what the user would prefer to use over the other. I seem to like them both, they both have their pros and cons. I grew up with TLs' but I have been using FLs' more. We'll see what I would end up with when I get my own place.
Post# 1056300 , Reply# 8   1/2/2020 at 16:56 (1,667 days old) by bradfordwhite (central U.S.)   |   | |
![]() 2
Post# 1056315 , Reply# 10   1/2/2020 at 18:33 (1,667 days old) by combo52 ![]() |
![]() 6
![]() MT and then WP not wanting techs to replace just the bearings was just so much BS, MT and later WP was selling bearings alone all along for the commercial versions of these washers, liability had nothing to do with it, if the machine was going to fly into pieces after it had new bearings in the old tub there would be much greater risk with the machine in a laundromat with much higher use and people around it waiting for their launder to finish.
Post# 1056350 , Reply# 13   1/3/2020 at 06:01 (1,666 days old) by Yogitunes ![]() |
![]() 6
liability my butt.....most times for a job like Neptune bearing replacement falls more under a tech/company not wanting to do they job, and uses the liability as a scape goat...
time is money, plus most dont want to tear a machine down in someones home... even under warranty they didn't want to replace them...or the whole tub... when I bought one of the first 3000series, it had a computer glitch....they had 5 techs here working on it, basically the issue became worse as they worked on it...what they wanted to do was destroy it beyond repair so the warranty would issue me a new one...yet not make it look like sabotage by them... but Eugene is correct....bearings/seals cost around 20.00...and in about an hour, you can be up and running again... I have replaced every one of the machines I found, interesting though, once you replace them, you never have to do it again.... |
Post# 1056384 , Reply# 14   1/3/2020 at 11:09 (1,666 days old) by stricklybojack (South Hams Devon UK)   |   | |
![]() 7
Post# 1058252 , Reply# 16   1/20/2020 at 23:54 (1,648 days old) by MattL ![]() |
Explain freezing the bearing, is it to "shrink" it a tiny bit for easier installation? I've replaced Duet bearings and they can be a pain to seat. |
Post# 1058261 , Reply# 17   1/21/2020 at 02:10 (1,648 days old) by bradfordwhite (central U.S.)   |   | |
![]() Freezing has worked for "pretreating" several things. Bearings would as well.
Also, a bearing press if need be.
Post# 1058268 , Reply# 18   1/21/2020 at 07:38 (1,648 days old) by combo52 ![]() |
![]() 3
![]() But they get all wet from condensation as you install them which is not ideal, I have tried it and did not see that it helped and did not like wet bearings.
Hi Keith, a bearing press is useful for many things, We have one like the one pictured but it is useless for installing FL washer bearings as it is too small to get the outer tub into it.
They make bearing installing tools to easily pull the bearings into place, we have a 1/2 dozen different ones that cover almost any machine.
John L.
Post# 1058270 , Reply# 19   1/21/2020 at 08:44 (1,648 days old) by Yogitunes ![]() |
![]() 2
I done at least 2+ dozen Neptune bearings.....
takes just over an hour start to finish... simple hand tools out of the garage, removed and replaced...some are a little more difficult, others remove and install with ease.... I have done it with the outter tub removed, and with it still installed in the machine... interesting though, once new ones were installed, never had another issue with the bearing/seals....at least on the ones I kept...YMMV Neptunes are probably one of the easiest to replace bearings in... |
