Thread Number: 81543
/ Tag: Modern Dishwashers
Whirlpool Dishwasher from 2011 |
Post# 1055774 , Reply# 1   12/28/2019 at 09:02 (1,672 days old) by IowaBear (Cedar Rapids, IA)   |   | |
![]() 2
![]() I have the same model in white...I bought it new. I believe it's the point voyager system. Mine has been trouble free for nearly a decade (with light use, normally once per week.) It's not really quiet but that's not an issue for me. If you Google Whirlpool point voyager you can easily find the technical manuals for this design. Using a good detergent and the heat-boosted wash it always cleans well.
My only complaint is that the detergent dispenser doesn't seal well. If I use one of the fancy detergent pacs containing separate liquids the pac will partially disintegrate during the prewash and the liquids will leak out. So I usually listen and toss in the pac when the main wash starts.
I don't know if the poor sealing was always a problem or if started with age but I'm not inclined to spend $45 to fix it. It really just needs a new seal on the dispenser, not an entire dispenser itself. |
Post# 1055795 , Reply# 3   12/28/2019 at 11:49 (1,672 days old) by IowaBear (Cedar Rapids, IA)   |   | |
![]() 2
![]() If you are very observant you might notice it draining and filling during the wash cycle itself. This was a mystery to me until I read the service docs.
The APF (Automatic Purge Filtration) wash system allows the control to continuously filter and flush |
Post# 1055821 , Reply# 4   12/28/2019 at 17:11 (1,672 days old) by imperial70 ![]() |
I'm not sure I notice because the draining on this machine is ultra quiet. They are not kidding when they say Quiet Partner II. :-) But I did read that the machine is has jets that clean something out every now and again. |
Post# 1055837 , Reply# 5   12/28/2019 at 19:56 (1,672 days old) by bradfordwhite (central U.S.)   |   | |
