Thread Number: 81556
Has anyone in Australia seen this particular machine? |
Post# 1055858   12/29/2019 at 05:37 (1,671 days old) by Adam-aussie-vac ![]() |
This machine I saved from the scrapheap as the only issue with it was a blocked pump apart from the current condition of the cabinet
Post# 1055865 , Reply# 2   12/29/2019 at 08:36 (1,671 days old) by Adam-aussie-vac ![]() |
Post# 1055866 , Reply# 3   12/29/2019 at 08:37 (1,671 days old) by Adam-aussie-vac ![]() |
Post# 1055907 , Reply# 4   12/29/2019 at 16:36 (1,671 days old) by Adam-aussie-vac ![]() |
Post# 1055910 , Reply# 5   12/29/2019 at 17:53 (1,671 days old) by Iej (.... )   |   | |
New seals and clean the hard surfaces with mild chlorine bleach. You can't get that kind of mould out of rubber. |
Post# 1055963 , Reply# 7   12/30/2019 at 10:45 (1,670 days old) by Aquarius1984 (Planet earth)   |   | |
I’m not sure if you have “Thick Bleach” in Australia - chlorine with surfactants abs soap/ detergent combined. I’ve cleaned doorseals in a very similar state to this several times by soaking it in a full 750ml bottle of thick bleach mixed with just enough water to cover the seal. After 24 hours there won’t be a mould mark on it at all.
If you don’t have thick bleach I would suggest you scrub it first using a cream cleaner like Jif to get the worst of it off then soak fully covered in a neat solution of thin chlorine bleach/ white knight bleach for 24 hours. You may be able to get thick bleach in UK import shops? |
Post# 1055970 , Reply# 8   12/30/2019 at 12:32 (1,670 days old) by Brisnat81 ![]() |
Thick bleach here would be Domestos. Just make sure you only use one chemical at a time. Don’t mix bleach products with anything else. |
Post# 1055974 , Reply# 9   12/30/2019 at 14:01 (1,670 days old) by iej (.... )   |   | |
You could try running it through a few hot cycles in the dishwasher with an older style detergent that contains bleach. Some of those are still available. |
Post# 1055977 , Reply# 11   12/30/2019 at 15:06 (1,670 days old) by iej (.... )   |   | |
www.amazon.fr/BRANDT-SOUF... A good search around should find plenty of options. |
Post# 1055978 , Reply# 12   12/30/2019 at 15:07 (1,670 days old) by iej (.... )   |   | |
Another video (with French voice over) that explains how to swap the door seal: www.systemed.fr/videos-br... |
Post# 1055996 , Reply# 13   12/30/2019 at 17:52 (1,670 days old) by Aquarius1984 (Planet earth)   |   | |
