Thread Number: 81926
wet clothes after spin |
Post# 1059509 , Reply# 1   2/3/2020 at 12:36 (1,543 days old) by Repairguy (Danbury, Texas)   |   | |
If it’s not spinning at all it could be the timer. After the machine completes the neutral drain there is a short pause in the timer that stops the motor allowing the transmission to shift to spin once the power is resumed to the motor after the pause. I’ve seen this a couple of times over the years where the timer skips the pause so the transmission never shifts to spin at the end of the cycle. If at the end of the cycle you find that the machine did not spin at all you can turn the timer back to spin and it will spin if this is the issue. This is ONLY the problem if the washer has not spun at all at the end of the cycle. If it is spinning just not good enough this is not the issue.
Post# 1059541 , Reply# 2   2/3/2020 at 20:30 (1,542 days old) by mhorn (mount bethel pa)   |   | |
it seems to go thru all the cycles, neutral drain,,, all water pumps out, then it pauses and bag, goes into spin but i dont feel its fast enough and clothes come out very wet |
Post# 1059543 , Reply# 3   2/3/2020 at 20:40 (1,542 days old) by DADoES (TX, U.S. of A.)   |   | |
