Thread Number: 82169
/ Tag: Vintage Dryers
Maytag DE806 Dryer |
Post# 1061847 , Reply# 1   2/29/2020 at 14:38 (1,122 days old) by hobbyapocalypse ![]() |
with dryer empty, shut-off solenoid should activate as follows:
Regular Dry = 9 to 11 minutes Permanent Press = 12 to 19 minutes Do you have the bar or the wire baffles? They are the baffles inside the drum, the newer ones have two metal bars on top, the older ones are wrapped with a wire. I had loose connections on my electronic control board and it caused weird things to happen so you ought to check that too. |
Post# 1061855 , Reply# 2   2/29/2020 at 15:48 (1,122 days old) by LowEfficiency ![]() |
Post# 1061880 , Reply# 5   2/29/2020 at 17:58 (1,122 days old) by Repairguy (Danbury, Texas)   |   | |
Post# 1061887 , Reply# 6   2/29/2020 at 19:37 (1,122 days old) by Tomturbomatic ![]() |
Great! |
