Thread Number: 82401  /  Tag: Vintage Dishwashers
POD - 3 - 24 - 2020 Waste King Dishwasher
scroll >>> for more items
Post# 1064392   3/24/2020 at 07:39 (1,098 days old) by turquoisedude (.)
turquoisedude's profile picture
Well, now...  Just as I lament about when I'm going to be able to get into the 'states again to pick mine up.  What a tease.
The one in the POD has to be one of the very first - the dial on the one I recently found is not like this one.  What year would this have been?  I always thought 1958.
Post# 1064397 , Reply# 1   3/24/2020 at 08:41 (1,098 days old) by chachp (North Little Rock, AR)
I can't wait for you to get it :)
chachp's profile picture
That machine deserves a glass door so we can see it in action!!!  It looks to be in such nice shape!!!  I'm sure you'll have it before you know.
Post# 1064398 , Reply# 2   3/24/2020 at 08:50 (1,098 days old) by seedub (South Texas Hill Country)
seedub's profile picture
Dewd looks like he's about to push it off that rock ledge they're standing on.
Post# 1064406 , Reply# 3   3/24/2020 at 09:57 (1,098 days old) by philcobendixduo (San Jose)
I like how....
philcobendixduo's profile picture
......the dial looks like a disposal stopper.
Post# 1064418 , Reply# 4   3/24/2020 at 11:34 (1,098 days old) by Tomturbomatic (Beltsville, MD)
This is later than '58 I think; more like 59 or 60 because I don't think the first year had a model with the buttons. I am only basing this on the BH&G issue that had an article on new dishwashers and I remember the picture of the three cycle buttons on the WK, but it did not show the dial and your dial is different than this dial but the buttons are the same. The article showed the deluxe Mobile Maid with the cycle buttons and that was only available starting in 1960. If any of you have a stash of old BH&G issues, I think the cover has a big picture of spaghetti. If I have time, I will look for it.
To those wondering about the positioning of items in the lower rack, note the pictures of the small plates in those corner tines and the small bowls along the side.
Post# 1064423 , Reply# 5   3/24/2020 at 13:05 (1,098 days old) by golittlesport (California)
golittlesport's profile picture
Interesting to note that in the text description of the full cycle, it mentions that it flushes "suds" away before the rinse. Dishwasher detergents never produced suds, even back in the good old days when washing machine detergent and soap manufacturers touted having a thick layer of suds to ensure clean clothes.
Post# 1064431 , Reply# 6   3/24/2020 at 15:09 (1,098 days old) by chachp (North Little Rock, AR)
Suds Flush
This is how the manual defines that sequence.
Post# 1064435 , Reply# 7   3/24/2020 at 15:52 (1,098 days old) by turquoisedude (.)
Ah, so a fancy way of saying "purge" like the D&M machines of this era would do.
Post# 1064442 , Reply# 8   3/24/2020 at 16:37 (1,098 days old) by Tomturbomatic (Beltsville, MD)
The fine holes in the wash arm did produce suds. I have opened the door during this flush and there was a lot of suds, like a layer across the bottom of the tank larger than the filter. The terminology that the water "enters on top of the suds" is achieved by the upward angled fill flume like in KitchenAid dishwashers that threw the fill water upward to make the most of the pre-washing warm up spray. Another possible explanation might be gleaned from the ads for Dishwasher All with the blue-gray mug in the rack and Electrasol where they talk about a formula that reduces protein foam from eggs and meats. This was especially prevalent in machines without a pre-rinse which the first WKs didn't have.
This post was last edited 03/24/2020 at 17:02
Post# 1064445 , Reply# 9   3/24/2020 at 17:19 (1,098 days old) by appnut (TX)
appnut's profile picture
To this day, I can still hear in my head that 1/2 minute of the water entering the tub while it was still in pump out mode (courtesy of the drain solenoid still being open).  It worked quite well.  I think I also probably opened it up at the end of the main wash when I was old enough to realize what was going on.  I'm a bit flustered right now.  Yes, ours, bought sometime in 1960 or early 1961 (because it got moved to the new house September, 1961 to replace the O'Keefe & Merrit Dual Drench dishwasher that was part of the  O'K&M kitchen).  And in the library list, it was attributed as being a 1961 model.  The 1964 version of this had the reversing motor for draining and dual level wash arms (like our 1968).  The 1964 knob had removed with "wing" used to grasp and pull out the knob.  It was a design that user turned the knob to the start segment and pushed in or pulled out the knob.  The 1964 also had the same red idiot light on the panel as pictured here, where by ours and the one Paul is getting) had the dual pastel-colored emblem light on the panel.  And those little red idiot "on" lights were the same even on our 1968 and friend's 1972 unit.
Post# 1064452 , Reply# 10   3/24/2020 at 17:46 (1,098 days old) by appnut (TX)
Tom, I just studied the ad that's the subject of the POD.  The wash arm spray patterns are just like a "typical" wash arm and spray pattern.  Not like the multiple small holes as was shown in Paul's future dishwasher as well as most likely ours.  So, this is a newer model than ours.
Post# 1064460 , Reply# 11   3/24/2020 at 18:20 (1,098 days old) by Tomturbomatic (Beltsville, MD)
Do you mean the drawing of the wash arm with the six lines emerging upward from it? I don't see a true to life shot of the wash arm in the ad that would agree with the drawing with the six little lines drawn emerging from it because the wash arm is under and behind the lower rack . Mine downstairs has the wash arm with the multiple small holes. It has this front panel and dial. The wash arm did not change during this model run.
Post# 1064479 , Reply# 12   3/24/2020 at 20:22 (1,098 days old) by appnut (TX)
ok.  thank you.
Post# 1064486 , Reply# 13   3/24/2020 at 21:03 (1,098 days old) by Tomturbomatic (Beltsville, MD)
Bob, I do seem to remember that the jets in the sort of reddish-orange almost Z-shaped wash arms in the WK portable were more like slits in bumps like the KA wash arms so that was a change during the first run. I stand corrected. That machine was so far ahead of its time; it would have spoiled a user for most other machines of the time even if the black lid was like something out of Brutalist architecture. Even that had the neat feature of the timer dial emerging through a hole at the front of the lid. I am sorry that I never got to see one operate.
Post# 1064531 , Reply# 14   3/25/2020 at 07:12 (1,097 days old) by appnut (TX)
tom, I vaguely remember seeing the top load at the dealer where we got both of our.  I was about 5 or 6.  they turned it on, had a clear demo lid.  I guess they were told I had such a fascination with appliances and turned it on briefly.  the reddish-orange left a lasting imipression.
Post# 1064534 , Reply# 15   3/25/2020 at 07:37 (1,097 days old) by chachp (North Little Rock, AR)
Photos
Does anyone have photos of this top load model.  If they have ever been posted I don't recall seeing them.  Thanks.
Post# 1064568 , Reply# 16   3/25/2020 at 12:56 (1,097 days old) by Tomturbomatic (Beltsville, MD)
Ralph, There have never been pictures posted. It is a very rare machine. Steve D. would be the only person here who Might have any info on it since he is the resident treasure trove of dishwasher information. Nobody but Bob has ever said anything about seeing one when I have mentioned it. I don't recall ever seeing a magazine ad for it and before Waste King became Waste King Universal, it was sort of out there on its own with just dishwashers and disposals. Portable dishwashers sort of had their golden moment in the late 50s into the 60s and then builders were installing built-in appliances in their new homes and the market for portable dishwashers kind of diminished. Lots of times families would reach the point where they could buy a dishwasher and they would buy a portable and then after a short time, they would either move to a place with a built in or could afford to remodel their kitchen and install built in appliances. In either case, the portable often wound up in a corner of the basement covered up until it was donated or discovered by John or Jeff and made part of someone's collection.
Post# 1064572 , Reply# 17   3/25/2020 at 13:29 (1,097 days old) by chachp (North Little Rock, AR)
Thank you Tom.
I sure would like to see one but I understand.  The more I study the user guide for this machine, read peoples comments and hear about how it was used it sure seems like it was a really nice machine.  I've never seen one in person except from a distance years ago, so it's difficult to comment on how well it was made.  It sure sounds like these were premium machines for their time.  Based on what I know about newer model WK machines I guess I thought these were just as problematic.
Post# 1064573 , Reply# 18   3/25/2020 at 13:38 (1,097 days old) by Steved (Guilderland, New York)
Don’t have much
Thanks Tom but I have very little info on Waste King dishwashers prior to the mid 60’s. I have this small pic from the back of a brochure but not a lot of detail. I seem to remember something in a builders magazine which I’ll try to track down
Post# 1064574 , Reply# 19   3/25/2020 at 13:39 (1,097 days old) by Steved (Guilderland, New York)
Also found
From a 1957 brochure. Showing the control panel. I will do some better scans when I can access my scanner
Post# 1064576 , Reply# 20   3/25/2020 at 13:49 (1,097 days old) by Steved (Guilderland, New York)
Plus I think
This is a Waste King timer knob. I remember seeing a dishwasher at the curb on trash day and I grabbed the knob from it.
Post# 1064581 , Reply# 21   3/25/2020 at 14:28 (1,097 days old) by appnut (TX)
Steve, that timer knob is from a 1964 or later dishwasher--after they'd changed to reversing motors.  There's a 1964 usre gide in the library and it has that knob style.
Post# 1064582 , Reply# 22   3/25/2020 at 14:29 (1,097 days old) by bigalsf (Salt Lake City)
Timer Knob
Yes, definitely from a WasteKing, circa 1964-67 (or thereabouts). Literature for these appliances is extremely hard to find.
WasteKing's cycling was different between models. Lower end models had a cycle sequence which went as PW (long),W,R,R,R,D. Mid-level to TOL models added a rinse between the pre-wash and main wash (PW,R,W,R,R,R,D). These full cycle differences carried through their model line until the late 70's/early 80's. It appears your knob comes from a lower end model (no offense intended). A good friend of our family's had a model with this style timer dial. I always thought is was cool design.
Hang in there Paul! It will be worth the wait! :)
Post# 1064583 , Reply# 23   3/25/2020 at 14:33 (1,097 days old) by appnut (TX)
ON our 1968 model, when Fine China was selected, the 3rd post-wash rinse (and 155+ water heat dwell) was eliminated.  My mom used Fine China most of the time as it shortened the cycle.
Post# 1064597 , Reply# 24   3/25/2020 at 15:59 (1,097 days old) by chachp (North Little Rock, AR)
Thanks for the photos
Why am I so tickled by "Sparkle Rinser"?  I have always liked the look of these.  I think Hazel had one of these when she moved in with the other family in the later episodes.
Post# 1064601 , Reply# 25   3/25/2020 at 16:47 (1,097 days old) by Tomturbomatic (Beltsville, MD)
Sparkle Rinser was their term for a rinse agent dispenser.
Funny that their convertible portable shows a picture of what looks like a toploader.
Post# 1064602 , Reply# 26   3/25/2020 at 17:06 (1,097 days old) by pulltostart (Mobile, AL)
Tom,
pulltostart's profile picture
I found a BH&G issue with spaghetti on the cover, but nothing about dishwashers in that issue.  The one I looked at is March 1961.  I looked back as far as August 1958 - no more spaghetti.  I will keep looking.
lawrence
Post# 1064622 , Reply# 27   3/25/2020 at 21:31 (1,097 days old) by Tomturbomatic (Beltsville, MD)
Sorry, Lawrence. I think it has to be 1961 because of the photo of the pushbuttons on GE Power Shower Portable. Do you have any other 1961 issues? Another neat picture I remember is the free-standing Waste King model with the drop leaves on each side which locked into the up position to make a table.
Post# 1064625 , Reply# 28   3/25/2020 at 22:00 (1,097 days old) by pulltostart (Mobile, AL)
I do have the rest of 1961.  I can look through the magazines and see if I can find what you're describing.
lawrence
Post# 1064650 , Reply# 29   3/26/2020 at 00:46 (1,097 days old) by Tomturbomatic (Beltsville, MD)
You don't have to look through them. The report was listed on the cover and would be in the contents at the front.
Post# 1064814 , Reply# 30   3/27/2020 at 14:40 (1,095 days old) by Steved (Guilderland, New York)
Rare top loader
Hey I found a little better pic from an eBay auction. I don’t think the pic is still available. Looks to be fairly BOL with no lift up top rack. I’m sure, based on the photo, that the interior is plastisol- lined.
Post# 1064852 , Reply# 31   3/27/2020 at 21:01 (1,095 days old) by Tomturbomatic (Beltsville, MD)
WOW! Thank you, Steve!
Oh yes, the interior was Plastisol lined. I thought it was so neat that the lid closed down over the timer dial and had a hole for it. I can't imagine that the black lid like on the model I saw went over very well with most women.
