Thread Number: 82503
/ Tag: Vintage Dishwashers
Kitchen Aid Imperial by Hobart Dial does not crank - machine does not start |
Post# 1065661 , Reply# 1   4/2/2020 at 18:33 (1,089 days old) by vacman1961 (North Babylon, New York)   |   | |
When you lived the handle does the push buttons pop out to reset the cycle? What model is it a KDI17? |
Post# 1065892 , Reply# 3   4/4/2020 at 14:36 (1,088 days old) by RP2813 ![]() |
![]() I'm not 100% certain but the machine appears to be a KDI-18. There should be a sticker on the side of the inner door panel with model information.
I'm more familiar with model series 20 and later. Those have a couple of screws on each side that hold the control panel in place. If you see a similar configuration on your machine, remove those screws and the timer & button assemblies should be made accessible to take photos and/or make repairs. |
Post# 1065894 , Reply# 4   4/4/2020 at 14:46 (1,088 days old) by RMoline (Moline, IL)   |   | |
Thanks for that - It is a KD-18. I had looked earlier and didn't notice it. |
Post# 1065964 , Reply# 5   4/4/2020 at 20:46 (1,087 days old) by appnut ![]() |
Post# 1066005 , Reply# 7   4/5/2020 at 07:10 (1,087 days old) by combo52 ![]() |
![]() 4
![]() Hi, To start this DW you just latch the door and push a cycle button, you do not have to move the timer knob. The DW will start in a few minutes if it is working properly.
It sounds like if you can not get it to start you may have a timer or door interlock switch problem or even a push-button switch problem.
These things are easy to fix for a tech that is familiar with KA DWs, find a tech that has been in business for at least 30 years and has gray [ or no ] hair. Even though parts are not available from WP-KA any longer these machines were so popular that parts can be fond on eBay etc.
Post# 1066481 , Reply# 8   4/8/2020 at 13:45 (1,084 days old) by RMoline (Moline, IL)   |   | |
Thanks all! I've found an appliance repair man that I'm hopeful will be able to fix it next Monday. I appreciate so much assistance and help. This group is full of fantastic people! |
Post# 1067525 , Reply# 9   4/15/2020 at 16:47 (1,076 days old) by varicyclevoice ![]() |
Post# 1067540 , Reply# 10   4/15/2020 at 18:26 (1,076 days old) by appnut ![]() |
