Thread Number: 82525
/ Tag: Wanted to Buy Items
Wanted: Maytag Brake Remover tool (038315) or dimensions |
Post# 1065896 , Reply# 1   4/4/2020 at 14:52 (1,482 days old) by goatfarmer (South Bend, home of Champions)   |   | |
Post# 1065898 , Reply# 2   4/4/2020 at 15:02 (1,482 days old) by d-jones (Western Pennsylvania (Pittsburgh Area))   |   | |
but John(combo52)recommends using a pair of vice grips clamped on to the edge of the brake assembly and then whacking the side of the vice grips with a plastic hammer to knock the brake loose. He works on these machines for a living and says that tool is clunky and awkward to use. I have this tool but I've never had an opportunity to use it. Still, I'd trust him on this.
Post# 1065956 , Reply# 3   4/4/2020 at 20:08 (1,482 days old) by robbinsandmyers (Conn)   |   | |
These are the only ones available online from what I searched.
CLICK HERE TO GO TO robbinsandmyers's LINK on eBay |
Post# 1066021 , Reply# 4   4/5/2020 at 10:27 (1,481 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Wow $60+ for a nearly useless tool that is a little dangerous to use.
I should have tried selling the three I threw in the scrap bin a year or so ago, but I could not sell one in good conscience.
When using a Vice-Grip to remove MT Brake you might have to use more than a plastic mallet, but I have never had one put up much of a struggle unless the whole machine sat in a foot of water and the threads are too corroded to remove in which case the damper and the steel washer base are toast anyway.
Post# 1066133 , Reply# 5   4/5/2020 at 21:31 (1,481 days old) by eurekastar (Amarillo, Texas)   |   | |
Post# 1066197 , Reply# 6   4/6/2020 at 09:24 (1,480 days old) by LowEfficiency (Iowa)   |   | |
