Thread Number: 82642
1986 GE Filter Flo — clutch removal |
Post# 1067526 , Reply# 1   4/15/2020 at 16:56 (1,070 days old) by Yogitunes ![]() |
Post# 1067539 , Reply# 2   4/15/2020 at 18:13 (1,070 days old) by StuftRock1 (Kentucky)   |   | |
Yes, it is quite filthy. Makes identifying the wires by color quite a pain... Unfortunately, even with the pin removed, the outer drum won’t budge. |
Post# 1067543 , Reply# 3   4/15/2020 at 19:05 (1,070 days old) by bendixmark (Winchester Mass)   |   | |
I used to pull those drums off with a wheel puller back 30 years ago.You need a transmission also. |
Post# 1067606 , Reply# 4   4/16/2020 at 11:40 (1,069 days old) by StuftRock1 (Kentucky)   |   | |
Do you need a wheel puller to get it off? |
Post# 1067654 , Reply# 5   4/16/2020 at 16:47 (1,069 days old) by bendixmark (Winchester Mass)   |   | |
I never got one off without one.They come off easily with the puller that has the three arms. |
Post# 1067740 , Reply# 6   4/17/2020 at 07:33 (1,068 days old) by eronie ![]() |
Yes these 2 speed clutches can be a pain to get apart. Years ago I used one on a homemade go cart. Can anyone explain how the variable speed one worked? |
Post# 1068000 , Reply# 8   4/18/2020 at 18:31 (1,067 days old) by eronie ![]() |
Use a 3 leg wheel puller. |
