Thread Number: 82880
Westinghouse Eighteen |
Post# 1070946 , Reply# 1   5/5/2020 at 09:39 (1,057 days old) by turquoisedude ![]() |
Post# 1070962 , Reply# 3   5/5/2020 at 12:42 (1,057 days old) by Unimatic1140 ![]() |
Post# 1071025 , Reply# 4   5/5/2020 at 19:54 (1,056 days old) by combo52 ![]() |
![]() It is either a bad timer or the motor centrifugal switch, if you can get the motor to start and run at any point on the timer over and over you do not have a bad CS, The CS on these WH motors are a weak point and difficult to fix, but anything is possible.
Getting to the CS is not easy, you have to remove the motor and dissemble the water pump and take the motor apart to even get to the CS, usually the motor shaft is very rusted and you will need at least a new pump seal etc.
Post# 1071132 , Reply# 5   5/6/2020 at 15:24 (1,056 days old) by Aquatop (South Dakota)   |   | |
Whelp, no joy on both running empty and also pressing the lid switch while trying to manually spin-start the tub. Sounds like the CS might be above my pay grade. |
Post# 1071147 , Reply# 6   5/6/2020 at 18:34 (1,055 days old) by cfz2882 (Belle Fourche,SD)   |   | |
Are you anywhere close to Belle Fourche? |
Post# 1071158 , Reply# 7   5/6/2020 at 20:29 (1,055 days old) by aquatop (South Dakota)   |   | |
Wait, really?? I'm in Spearfish! lol |
Post# 1071161 , Reply# 8   5/6/2020 at 22:07 (1,055 days old) by cfz2882 (Belle Fourche,SD)   |   | |
Hehe,you are very close :)...I fix motors and washers,should be able to get it going again,we will have to arrange something :) |
Post# 1091046 , Reply# 10   9/28/2020 at 15:31 (911 days old) by goatfarmer ![]() |
![]() 2
