Thread Number: 83092  /  Tag: Vintage Automatic Washers
water saving in bendix diving bell question
scroll >>> for more items
Post# 1073912   5/23/2020 at 09:39 (1,035 days old) by dryclean1 (Walton, NY)
hello fellow washer nuts. its me the drycleaner. I have a 1946 bendix model s or diving bell as they are called. I was reading on an old post about the semi-auto bendix model s. there was some discussing about a way to run the drain line into the top of the washer to re-use water if you wanted to. I have tried this with mine using a fernico adapter and I get a lot of spay over with it. did they make a special adapter for the drain hose that fit in the top where the detergent goes? any suggestions would be great. thanks the drycleaner
