Thread Number: 83094
New toys - Questions about a Westinghouse L110 and D110 washer and dryer set |
Post# 1073915   5/23/2020 at 10:56 (1,032 days old) by turquoisedude ![]() |
![]() Yes, it's warm enough for me to be playing outside again and as seems to be typical for me, I have a new toy to play with which has jumped to the front of the 'appliance to-do' list.... LOL I recently acquired a Westinghouse L110 laundromat washer - a 1957 model I believe. It works but it needs a bit of work; specifically the rear tub bearing is shot. I also snagged the almost-matched dryer - it's a 1958 model built in Canada. I have read the washer doctrine (thank you for making it available here, Robert!) and I have a pretty good idea of what I will have to do. But we all know there are pitfalls and "dammit" moments... Are there any "don't do this" things I should be aware of? While I have done plenty of work on Laundromats, I am not familar with bearing replacement... A more specific question - what is 'calcium-based' grease? The service literature says to use this below the new seals after the bearing is in; I can't say that I have ever heard of this before.... Lastly, the door seal on the dryer is shot to hell - does anyone know the part number for this? Dryer works wonderfully otherwise. Oh, wait, I shouldn't have said that...LOL Hopefully I will be posting lots of smiling, happy "after" pictures and videos soon! |
Post# 1073923 , Reply# 1   5/23/2020 at 11:36 (1,032 days old) by Golittlesport (California)   |   | |
While it is said the later true horizontal tub Westy Laundromat machines tangled less and cleaned better, I love those 1950's Westy Laundromats with the slanted, bowl-shaped tubs. And 1957 model is probably the prettiest of them. Best of luck with the work ahead of you! Will look forward to pics and vids.
What does the almost-match dryer control panel look like? |
Post# 1073927 , Reply# 2   5/23/2020 at 11:49 (1,032 days old) by turquoisedude ![]() |
![]() Here's a picture for you! It looks like the 1957 US version with all the pretty pushbuttons and light-up timer dial.
Post# 1073945 , Reply# 3   5/23/2020 at 15:45 (1,032 days old) by appnut ![]() |
Post# 1073963 , Reply# 4   5/23/2020 at 17:15 (1,032 days old) by turquoisedude ![]() |
Post# 1073988 , Reply# 5   5/23/2020 at 19:30 (1,032 days old) by bradfordwhite ![]() |
Post# 1074087 , Reply# 6   5/24/2020 at 12:21 (1,031 days old) by Bendixmark (Winchester Mass)   |   | |
I have that washer.Mine is a 3 belt.Didnt know the dial changes colors. |
Post# 1074273 , Reply# 7   5/25/2020 at 14:10 (1,030 days old) by turquoisedude ![]() |
![]() Any restoration has its challenges. Even when you have some experience restoring a machine like what you are currently working on. Well, I'm stuck... More precisely, the inner wash tub of the Westy L110 is. Danged thing won't budge when I try to lift it out. The other 2 Laundromats I've worked on did not do this. Am I missing something? Also an important reminder to always use the Westinghouse shipping braces if you have to transport a Slant-Front Laundromat... see the torn tub in picture 2... (PS - I will happily lend a set of shipping braces to anyone who may need them!!) |
Post# 1074320 , Reply# 8   5/25/2020 at 21:14 (1,030 days old) by Bendixmark (Winchester Mass)   |   | |
When my machine like that arrived from New York the tub was on its side in the cabinet. Myself and a friend had to put it back together like Humpty Dumpty. |
Post# 1074322 , Reply# 9   5/25/2020 at 21:16 (1,030 days old) by Bendixmark (Winchester Mass)   |   | |
Post# 1074369 , Reply# 10   5/26/2020 at 09:22 (1,029 days old) by combo52 ![]() |
![]() Hi Paul you will probably have to press it out and it may come out with the inner bearing, not too surprising that it has a failed seal and stuck shaft given the heavy mineral build-up the machine has from a lack of detergent usage.
The worn through outer tub is not likely from moving the washer without the shipping braces so much as operating the machine for an extended time with a snubber out of position, the snubber bracket could only wear through the outer tub durning moving if you moved the machine across country by mule cart across the Rockies, LOL
Post# 1074387 , Reply# 11   5/26/2020 at 13:16 (1,029 days old) by rinso (Meridian Idaho)   |   | |
Post# 1074390 , Reply# 12   5/26/2020 at 13:41 (1,029 days old) by CircleW ![]() |
We had a '63 Westinghouse dryer that had color buttons like that. When I took it apart, I saw the switch button assembly was made by GE. |
Post# 1074400 , Reply# 13   5/26/2020 at 15:41 (1,029 days old) by turquoisedude ![]() |
![]() Not the best picture, but when I took the motor and pump assembly out of thd L110 Laundromat I could help but notice that the friction drive wheel that runs the drain pump is in poor shape. Anyone happen to know the part number for this? It's not in the Westy service manual... OR is there some method of repairing the rubber-like coating on the drive wheel??
