Thread Number: 83699
/ Tag: Twin-Tub Washers
Wanting to attach a spin dryer to a pump |
Post# 1080669 , Reply# 1   7/11/2020 at 18:21 (985 days old) by Launderess ![]() |
Don't think you're missing much luv.
Chucking out pan or bucket of water is a bit of work, but not much really IMHO. Suppose if one were doing several loads in succession it would be a bit of bother, but nothing that can't be endured I shouldn't wonder. Problem with a pump is you don't know if it will be able to handle what could be great amounts of water gushing out at once. Washing machines of course will slow down spinning to prevent choking pump, you'd probably have to rig up something that allowed pump to continue even while machine isn't spinning (assuming you stopped things to let water in sump get clear). Gravity drain shines in that respect in that there isn't a pump to worry about, so water drains fast as opening will allow. One rarely sees drain pumps on industrial or commercial washers (though many can be ordered with), for that reason. Valve opens, and machine dumps water. My Hoover twin tub spin drier has a pump and one has to watch things for froth or water build up. It doesn't like it... |
Post# 1080714 , Reply# 2   7/12/2020 at 03:09 (984 days old) by Adam-aussie-vac ![]() |
Thank you so much for your advice Laundress |
Post# 1080804 , Reply# 4   7/12/2020 at 19:20 (984 days old) by Launderess ![]() |
Don't ask....
Ten sheets spun two or three at a time in spin dryer after coming out of tubs. Keep a large bucket near, it's basically same one use to carry wet laundry from tubs to spin dryer. After one or to loads dump water from pan into bucket. When going back to tubs empty bucket, fetch more laundry, and repeat..... Yes, suppose it tis a bit of work, but had wanted to take easy way out would have spent several hours doing the lot in either Miele or AEG automatic washers. That or gone to local laundromat and bunged the lot into 50lb washer. My take on things if one is already going down that rabbit hole, a bit more drama isn't going to make difference. |
Post# 1080833 , Reply# 6   7/13/2020 at 04:43 (983 days old) by Launderess ![]() |
Get a bit of clean cloth and after pushing down load in spin dryer fit it around top of load. Then close lid and start spin dryer. The cloth serves two purposes; it will keep items from being rubbed against inside of lid, and prevent small items from going over top of tub.
In your situation will also keep any bits of whatever from getting on your wash. When spinning is done carefully fold cloth inwards to keep any bits from falling out onto wash. |
Post# 1080838 , Reply# 7   7/13/2020 at 06:05 (983 days old) by thomasortega ![]() |
What's the drum diameter? I have several safety covers here, maybe one can fit. |
Post# 1080839 , Reply# 8   7/13/2020 at 06:06 (983 days old) by thomasortega ![]() |
Silly question: do you have a floor drain somewhat near the spin dryer? |
Post# 1080840 , Reply# 9   7/13/2020 at 07:00 (983 days old) by Adam-aussie-vac ![]() |
I currently do have a spin mat That fits my spin dryer but thank you for the advice |
Post# 1080844 , Reply# 11   7/13/2020 at 07:33 (983 days old) by ozzie908 ![]() |
Due to its age I would think a good sanding and a coat of appliance paint would help stop the rust and flaking of enamel.
I have a number of spin dryers most have mechanical pumps one has an electric pump that runs as soon as you plug it in its great for rinsing as you can have it running into the sink. the others with mechanical pumps you have to be careful not to overwhelm it as it won't get up to speed to pump the water out also have a gravity drain which is in need of a bowl under the spout like yours. I would imagine that yours maybe from the 40's early 50's as no need for a safety lid if you were dim enough to put your arm in then that's your choice....lol Looking at your machine I think the best thing is either carry on as you are or get an old bowl and fix an electric pump to the underside so the spinner can evacuate at full tilt and the pump will catch up when its ready. Austin |
