Thread Number: 83935
Help! Whirlpool top loading automatic washer problem |
Post# 1082863 , Reply# 1   7/28/2020 at 20:02 (1,367 days old) by whirlykenmore78 (Prior Lake MN (GMT-0500 CDT.))   |   | |
If any cycle progression lights are flashing in sequence this would be helpful in determining the problem. There are Youtube videos of how to put the machine into diagnostic mode and read any error code it throws. Try this and let us know what happens. Otherwise I'm sure someone here with more knowledge than me will know what is wrong. WK78 |
Post# 1082867 , Reply# 2   7/28/2020 at 22:29 (1,367 days old) by DADoES (TX, U.S. of A.)   |   | |
It's a VMW. Lotta VMW trouble comes from flaky mode shifters (aka actuator). Lid locks are also a fairly common source. As mentioned above, there are YouTube vids on how to get into diagnostics to read fault codes and/or run manual function tests. Or someone here can surely outline the procedure. There should be a tech sheet in a pocket glued to the inside of the machine front but the top kinda needs to be raised up for access to reach it. |
Post# 1083126 , Reply# 4   7/30/2020 at 17:44 (1,365 days old) by DADoES (TX, U.S. of A.)   |   | |
Post# 1083584 , Reply# 5   8/2/2020 at 12:46 (1,362 days old) by Electroluxkid (Springfield PA)   |   | |
I just put it into diagnostic mode and I turned the knob and it showed a fill code |
Post# 1083598 , Reply# 6   8/2/2020 at 14:37 (1,362 days old) by DADoES (TX, U.S. of A.)   |   | |
Again, which specific code(s) are you finding? How to proceed depends on the code(s). The Tech Sheet for your model lists 22 fault codes (including No Code), of which perhaps 6 could be considered related to filling. Are you reading all the stored codes? There may 1, 2, 3, or 4 stored codes. After accessing diagnostic mode (all cycle lights flashing On - Off at 1/2-second intervals) ... Turn the knob until only Done is lit, then press Start. The first code is displayed. Turn the knob clockwise one click for each of up to 3 more stored codes (or turn counterclockwise to back up the reading). Codes are read in two parts -- F# and E# ... example F2E1. - First part has the first light (usually labeled Fill or Sensing) and none or one or more of the others (Wash, Rinse, Spin, Done) lit for 1/2 second. That is the F# part of the code. - All lights off for 1/2 second. - Then the first light is off and one or more of the others is lit for 1/2 second. That is the E# part of the code. - All lights off for 1/2 second. - The code repeats until the knob is turned for another code. The number of the F or E part is determined by the Wash light = 8, Rinse = 4, Spin = 2, Done = 1. None is 0. Add together the values to get the number. First light, plus Spin and Done is F3 (2+1) for example. First light and no others is F0. |
