Thread Number: 84068
/ Tag: Modern Dishwashers
AMKrayoGuy the Samsung King and his new Dishwasher! |
Post# 1084216   8/7/2020 at 10:39 (1,357 days old) by DaveAMKrayoGuy (Oak Park, MI)   |   | |
didn’t even know it was on, the inaugural cycle is a short one run empty, so i hope capacity and performance in the upcoming load will speak excellently for itself... the old one’s control board was on the verge of separating from its gasket, as had there. been a water leak in one corner under the door, requiring a bit of guff to latch...
—Dave |
Post# 1084254 , Reply# 1   8/7/2020 at 15:12 (1,357 days old) by appnut (TX)   |   | |
Post# 1084953 , Reply# 2   8/13/2020 at 12:28 (1,351 days old) by DaveAMKrayoGuy (Oak Park, MI)   |   | |
Well here's how she cleans:
This is actually the second load I've done, the first turned out near excellent but it was excessively wet in there despite using a rinse aid, so after applying it in the dispenser the supposedly right way, the dampness is under control, just need to empty her... Also the initial load was on Heavy Wash which I used again, only this time with the Sanitize, Storm Wash and even Extra Hot Wash Booster... -- Dave |
Post# 1084955 , Reply# 3   8/13/2020 at 13:23 (1,351 days old) by Cam2s (Nebraska)   |   | |
Does this have regular spray arms, or that water wall contraption? |
Post# 1084957 , Reply# 4   8/13/2020 at 13:53 (1,351 days old) by chachp (North Little Rock, AR)   |   | |
Post# 1084964 , Reply# 5   8/13/2020 at 16:30 (1,351 days old) by Iheartmaytag (Wichita, Kansas)   |   | |
Post# 1084994 , Reply# 7   8/13/2020 at 19:08 (1,351 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Post# 1085069 , Reply# 8   8/14/2020 at 16:00 (1,350 days old) by imperial70 (MA USA)   |   | |
I could never load a dishwasher like that. It's how do you expecto to wash plate on top of plate correctly. I have a point voyager that cleans really well but I would never think of expecting any dishwasher to clean item on top of item. |
Post# 1085070 , Reply# 9   8/14/2020 at 16:12 (1,350 days old) by DADoES (TX, U.S. of A.)   |   | |
Post# 1085075 , Reply# 10   8/14/2020 at 16:44 (1,350 days old) by eronie (Flushing Michigan)   |   | |
That's how a single arm KitichenAid did it!! |
Post# 1085128 , Reply# 11   8/15/2020 at 07:14 (1,350 days old) by DaveAMKrayoGuy (Oak Park, MI)   |   | |
Well, here is how.I put the rinse aid in just so I know how much is directly going in rather an endless amount that doesn't let me see when I just put it in a hole, and like I said, it's been much dyer in there...
The stuff's clean, and even a plastic pitcher that wouldn't fit in the top rack came out perfect without being melted or deformed in the bottom... -- Dave |
Post# 1085129 , Reply# 12   8/15/2020 at 07:16 (1,350 days old) by DaveAMKrayoGuy (Oak Park, MI)   |   | |
Post# 1085151 , Reply# 13   8/15/2020 at 11:04 (1,349 days old) by Taurn67 ()   |   | |
you add it at the start of the cycle with detergent? |
Post# 1085154 , Reply# 14   8/15/2020 at 12:00 (1,349 days old) by DaveAMKrayoGuy (Oak Park, MI)   |   | |
Post# 1085156 , Reply# 15   8/15/2020 at 12:25 (1,349 days old) by Taurn67 ()   |   | |
Rinse aid goes in the last rinse. From what I see, your dispenser is empty, fill it where the lines are beside the "MAX", not the little hole. |
Post# 1085159 , Reply# 16   8/15/2020 at 12:38 (1,349 days old) by DADoES (TX, U.S. of A.)   |   | |
Dave, your dishwasher has an automatic rinse air reservoir dispenser. It's not a one-shot thing separately for each load. You fill it with however much rinse aid it takes to the Full mark and then it dispenses automatically at the appropriate time (last rinse). It doesn't need to be refilled until it's near empty, a reminder signal should appear on the control panel. There's usually an adjustment to increase or decrease how much is released at each shot according to factors such as water hardness and what drying performance you want to get out of it. It may be a mechanical adjustment directly on the dispenser, or it may be an electronic adjustment through the control panel. Details should be in your Instruction Manual. |
Post# 1085470 , Reply# 17   8/18/2020 at 01:17 (1,347 days old) by DaveAMKrayoGuy (Oak Park, MI)   |   | |
Well, this time I didn't pour any (more) rinse aid in and this load came out completely dry...
Whatever was only a little annoyingly wet I just set in the dish drainer, just as with my old dishwasher... -- Dave |
Post# 1085479 , Reply# 18   8/18/2020 at 07:04 (1,347 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Post# 1085490 , Reply# 19   8/18/2020 at 09:42 (1,346 days old) by DaveAMKrayoGuy (Oak Park, MI)   |   | |
Post# 1085966 , Reply# 20   8/22/2020 at 00:22 (1,343 days old) by DaveAMKrayoGuy (Oak Park, MI)   |   | |
Post# 1085967 , Reply# 21   8/22/2020 at 00:24 (1,343 days old) by DaveAMKrayoGuy (Oak Park, MI)   |   | |
Post# 1086332 , Reply# 22   8/24/2020 at 13:46 (1,340 days old) by DaveAMKrayoGuy (Oak Park, MI)   |   | |
Another before:
Well, one plate short of a full load, which it finally got: As for the after, I'd better bend over, I "clean" forgot right when that last clean fork got put in the drawer and that last dirty coffee mug got placed in the top rack, before I realized I was supposed to take those pics... -- Dave |
Post# 1089862 , Reply# 23   9/19/2020 at 00:38 (1,315 days old) by DaveAMKrayoGuy (Oak Park, MI)   |   | |
Here's a before/after with third rack removed to accommodate some large items and luckily didn't have any real small items that would get lost without it as much as with a cake I baked and messy pasta going through my colander needed to get an "all of a sudden full load" done:
-- Dave |
Post# 1090446 , Reply# 24   9/23/2020 at 22:19 (1,310 days old) by Fisherpaykel (BC Canada)   |   | |
Wow Dave looks like your new machine can accommodate all your preparation dishes, utensils, cookware, tableware and leave you with no sink washing leaving you only to put away at the finish, very impressive, enjoy. |
Post# 1090454 , Reply# 25   9/24/2020 at 01:21 (1,310 days old) by DaveAMKrayoGuy (Oak Park, MI)   |   | |
Ah, yes---about the only thing I can't put in there is my ice cream scoop with the anti-freeze built into the handle, but I don't like washing anything by hand, so with me being the only one who uses it, just found some other "method" to getting the melted scooped ice cream off without soap, water and dish pan hands, since I'll never even need another dish pan again...
Besides, the ice cream right off of it tastes the best! -- Dave |
