Thread Number: 84200
/ Tag: Vintage Dishwashers
KDS-18 first timer need everything |
Post# 1085610 , Reply# 1   8/19/2020 at 10:57 (1,437 days old) by Jampen (Odessa)   |   | |
Post# 1085619 , Reply# 2   8/19/2020 at 11:50 (1,437 days old) by DADoES ![]() |
![]() It has what's called a rapid-advance timer. A separate motor on the timer runs at a faster speed when needed to quickly skip over functions that aren't used for the selected cycle. The Cancel button for example quickly jumps to the last drain period then to Off. Maybe that's part of the ticking noise you're hearing. |
Post# 1085623 , Reply# 3   8/19/2020 at 12:07 (1,437 days old) by Jampen (Odessa)   |   | |
Post# 1085663 , Reply# 5   8/19/2020 at 15:44 (1,437 days old) by jampen (Odessa)   |   | |
Anyone have list of part numbers for this unit? TIA |
Post# 1085694 , Reply# 7   8/19/2020 at 18:36 (1,437 days old) by qsd-dan (West)   |   | |
1. Soap dispenser door doesn't open properly
You'll have to check the bi-metals that are responsible for opening the dispenser cups. Sometimes they just need to adjusted, other times the connections to the wires are bad, which is common with leaks in that area. Lastly, they may need to be replaced. You'll have to run the dishwasher with the front cover off to make sure there's no leaks around dispenser cup shafts. They like to leak there with age. You can replace the o-rings if leaking. 2. It drained properly the first few cycles but now it has standing water in the bottom. You should hear a "click" when draining, this is the drain solenoid being activated. Check the wires and connections to the drain solenoid and make sure they're up to par. You can apply 120V directly to the drain solenoid for testing purposes. 3. Upper spray arm doesn't seem to be spraying. Top rack dishes not cleaned Your upper washarm assembly is toast, the shaft should not come out of the housing. They're obsolete but a few are still floating around. Here's one: https://www.ebay.com/itm/FSP-4162724-Dis... Carefully check the upper water delivery tube located in the upper rack, that runs between the wash arm and rear pipe of the rack. These can crack or rot out over time and cause a significant reduction in water pressure to the upper rack wash arm. Part # 4171544. This is what it looks like https://www.ebay.com/itm/OEM-Whirlpool-4... There's a bellows seal mounted on the back wall where the upper rack meets the water delivery tube. These deteriorate over time and will cause a reduction in pressure. These bellow seals were only used on 18 series dishwashers with an upper wash arm. The design was revised starting with the 19 series. They been obsoleted for many, many years and impossible to find now. Pray this isn't torn or missing. 4. Cycle indicator lights on front sometimes randomly jump around. It's common for the neon lights to flicker when they get old and on their way out. Multiple lights shouldn't be jumping around though. |
