Thread Number: 84224
/ Tag: Wringer Washers
Calling Brad Ross |
Post# 1085919   8/21/2020 at 16:23 (949 days old) by roscoe62 (Canada)   |   | |
Is this wringer washer fixable cosmetically? It has alot of rust on all of the wringer top & side pans, and lid but motors are working. |
Post# 1085944 , Reply# 1   8/21/2020 at 19:53 (948 days old) by bradross (New Westminster, BC., Canada)   |   | |
I've restored some machines, mostly Maytag, that were in really rough shape, but I knew what the outcome would be, so it was worth the work. And I wanted to actually use the machine on a regular basis.
It's difficult to give an assessment with just a few photos, but if the machine appears to be in good shape mechanically (including the wringer gear box/frame and rolls) then it may well be worth the effort and expense. You could have the wringer's drain boards re-chromed, but I imagine that wouldn't be cheap. Does it have a pump? If so, what's the condition? Would you be doing the work yourself? And do you plan on using it once restored? |
