Thread Number: 84241
/ Tag: Vintage Dishwashers
KDS-20 won’t fill, pics attached |
Post# 1086174 , Reply# 1   8/23/2020 at 15:51 (942 days old) by appnut ![]() |
Post# 1086262 , Reply# 3   8/24/2020 at 06:29 (941 days old) by ozzie908 ![]() |
I have read on here that its best to add a gallon of really hot water to wet the seals and help them expand again to make them water tight....!
Have you tried it since to see if still leaks? Good luck am sure you will get it going after all most of its ok if the timer and switches are working, On the water fill issue could it be the screen in the inlet is clogged? Austin |
