Thread Number: 84343  /  Tag: Vintage Automatic Washers
Whirlpool portable install timer troubles.
scroll >>> for more items
Post# 1087389   8/31/2020 at 13:12 (943 days old) by Vintagemh (Saskatoon )
Hello,
Got the washer and dryer in place and we are finishing up the cabinets. We bumped the washers timers a few times and now it will only turn when you turn the skirt not the knob. We haven't plugged them in yet since the install only sized them for the purposes of fitting them. I imagine the timer will still work on the washer but of course it bothers me that I can't turn it from the knob. Is getting a new timer out of the question, can I fix the old timer? How can I open the machine up to examine if something came loose? I'd like to at least lube the motor and moving components before we finish up the install.
We totally love these little green guys and would like to find a full size vintage pair (not for regular use, we just love vintage stuff). Just for comparison what does a full size version of these look like?
We purchased a foam circle and we intend to cut it to keep the washers tub from banging around when we drive.
Thank you all!
Post# 1087391 , Reply# 1   8/31/2020 at 13:37 (943 days old) by Pierreandreply4 (St-Bruno de montarville (province of quebec) canada)
vintage full size
the vintage full size of those would be this model with matching dryer this brand is inglis the canadien version of whirlpool
Post# 1087392 , Reply# 2   8/31/2020 at 13:52 (943 days old) by turquoisedude (.)
turquoisedude's profile picture
It sounds as if the shaft for that inner timer knob has broken - you may be able to glue it but you'd have to carefully remove the timer knob and then pull off the broken part from the timer shaft.   In a worst-case scenario, you may be able to find a replacement knob - if you have an appliance repair shop that also sells reconditioned machines near you, try them first.
Post# 1087398 , Reply# 3   8/31/2020 at 15:06 (943 days old) by Vintagemh (Saskatoon )
Inner Knob
The inner knob still pulls out and pushes back in but doesn't seem as connected as it was initially. Does anyone have any guidance on how to investigate? I'll be REAL careful!
Post# 1087434 , Reply# 4   8/31/2020 at 20:09 (943 days old) by combo52 (50 Year Repair Tech Beltsville,Md)
Broken Timer On A WP BD Compact Portable Washer
combo52's profile picture
Hi, You need another timer, although you may be able to still use the washer as long as you either push the timer knob in [ or unplug it ] when you manually advance it to set the cycle.
If you are really clever you may be able to fix the sheered part in the timer.
Good news is it is easy to replace the timer on these washers, you just use a putty knife to release the top at the front then remove the timer knob and dial the two screws behind the dial and lift out the timer and unplug from the harness.
John L.
Post# 1090106 , Reply# 5   9/21/2020 at 05:12 (922 days old) by Vintagemh (Saskatoon )
putty knife
I tried using the putty knife to open the top, is there a specific place I should be putting the knife? I felt some give when I pushed on some places but the top didn't open. Very appreciative of your help, is there anyone who would have a replacement timer I could purchase? Just trying to be very careful and not damage anything.
Post# 1090111 , Reply# 6   9/21/2020 at 07:08 (922 days old) by combo52 (50 Year Repair Tech Beltsville,Md)
I have one of these washers at my shop with the top up, I will try to take a picture and post it today.
John L.
Post# 1090144 , Reply# 7   9/21/2020 at 11:04 (922 days old) by Vintagemh (Saskatoon )
Thank You John!
much appreciated!
Post# 1090176 , Reply# 8   9/21/2020 at 18:20 (922 days old) by Combo52 (50 Year Repair Tech Beltsville,Md)
Raising the top on a portable whirlpool belt drive washer
The clip that needs to be pushed in with a putty knife is about 1 1/2 inches in from each side use a strong putty knife press in while you were pulling up on the top from inside the lid opening.
Post# 1090180 , Reply# 9   9/21/2020 at 18:47 (922 days old) by Maytag85 (Sean A806)
maytag85's profile picture
Pretty much opening the top up is similar to the full size belt drive washers and I have experience since I’ve lifted the top up on my Kenmore portable washer and full size 1963 RCA Whirlpool Imperial Mark XII washer.
Post# 1090198 , Reply# 10   9/21/2020 at 20:34 (922 days old) by combo52 (50 Year Repair Tech Beltsville,Md)
Lifting The Top Of A WP built BD Washer
Hi Sean, Similar is the operative word here, The clips on the compact washers are intentionally much tighter and you need to use a putty knife etc, while on the full sized washers you can just pull the top slightly forward and lift with no tools.
John L.
Post# 1093518 , Reply# 11   10/17/2020 at 11:19 (896 days old) by Vintagemh (Saskatoon )
tops open, now what
Hello,
SO what am I looking for, is there a clip that fell off thats making the timer knob stick out so far? Is there a source for a replacement timer?
Post# 1093520 , Reply# 12   10/17/2020 at 11:22 (896 days old) by Vintagemh (Saskatoon )
looks like a good opportunity to secure the loose plastic tub top that wiggles and makes a racket when it spins.
