Thread Number: 84464
/ Tag: Vintage Dishwashers
KDW-5 Help! |
Post# 1088649   9/9/2020 at 16:44 (930 days old) by Elginkid (Cincinnati, OH)   |   | |
We’re fixing the KDW-4 and one of the metal plates between the motor and gaskets has rusted out. Is this a piece that is a) still available, b) someone has one that they don’t need, c) replaceable with something besides metal? The gaskets are shot too, but that can be an RTV creation if they aren’t. Pictures below.
Post# 1088687 , Reply# 2   9/9/2020 at 21:36 (929 days old) by pdub ![]() |
![]() 2
Post# 1088746 , Reply# 3   9/10/2020 at 06:57 (929 days old) by Elginkid (Cincinnati, OH)   |   | |
Post# 1088748 , Reply# 4   9/10/2020 at 07:06 (929 days old) by combo52 ![]() |
![]() It is amazing what can be found, I would make the gaskets out a good rubber type gasket material rather than cork, cork works but is not as durable as a rubber type material and drys out and shrinks if the DW does not get used on a regular basis, this is where the [ now old wives tale ] came from that the gaskets can dry out in an unused DW, Washer etc.
The original drip shield would have also worked with a good coat of pro-15 etc, but new is better, since it is galvanized you may not need to paint it, but it won't hurt.
