Thread Number: 84857
LA 506 - cleaning, rust removal, and restoration |
Post# 1093266 , Reply# 3   10/15/2020 at 13:26 (1,289 days old) by Gyrafoam (Wytheville, VA)   |   | |
About 1/2 cup to a gal. Water. I have hard water. The Right Stuff is very thick like axle grease. Makes it easy to work with and dries quickly. Wear gloves. I find that plain rubbing alcohol gets it off if you catch it quick enough. |
Post# 1093276 , Reply# 4   10/15/2020 at 15:47 (1,289 days old) by dough77494 (TX)   |   | |
Gyrafoam, Searching the net found "Right Stuff" Permatex® Gasket Maker. Is "Right Stuff" applied as the final top coat over POR-015 or is POR-15 the final product applied? Thank you again for the benefit of your experience. Doug |
Post# 1093279 , Reply# 6   10/15/2020 at 17:03 (1,289 days old) by Good-Shepherd (New Jersey)   |   | |
WD-40 or other solvent/degreasers are useless on hard water deposits. Scotch Brite Pad can pad can scratch the porcelain. I wouldn't take any cleaning advice from your friend. |
Post# 1093286 , Reply# 7   10/15/2020 at 18:27 (1,289 days old) by Gyrafoam (Wytheville, VA)   |   | |
Two different things. POR-15 is used to stop rust. You can even paint it right over the rust. The Right Stuff is a sealant. Make your own gaskets or shmeer it around to seal an area from water. |
Post# 1093319 , Reply# 8   10/16/2020 at 02:03 (1,288 days old) by dough77494 (TX)   |   | |
Gyrafoam, Thanks for the clarification. Upon removal of all rust, will prep the surface, apply POR-15, followed by Right Stuff. Thank you! |
