Thread Number: 85408
Replacement for 20 year old Whirlpool |
Post# 1099554 , Reply# 2   12/6/2020 at 11:52 (1,236 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
The TR SQ machines are a good choice if you want good gentle performance and are not in a hurry, if you want something fast and through the SQ TC5 series is really your only choice in a rugged TL washer today.
SQs are in short supply because of high demand and because of production problems related to covid.
John |
Post# 1099557 , Reply# 3   12/6/2020 at 12:04 (1,236 days old) by appnut (TX)   |   | |
Post# 1099582 , Reply# 4   12/6/2020 at 15:02 (1,236 days old) by Yogitunes (New Jersey)   |   | |
Post# 1099665 , Reply# 5   12/7/2020 at 05:36 (1,235 days old) by retro-man (- boston,ma)   |   | |
No timers available to replace the one you have. It would seem to me someone here must have one or more sitting on a shelf somewhere. Jon |
Post# 1099826 , Reply# 8   12/8/2020 at 12:57 (1,234 days old) by GELaundry4ever (Nacogdoches, TX, USA)   |   | |
speed queen |
Post# 1099909 , Reply# 10   12/8/2020 at 23:08 (1,234 days old) by DADoES (TX, U.S. of A.)   |   | |
Coco2, 1) Use the Delicate cycle for a longer wash time. Sit with the machine or set a timer to monitor it and repeat the wash period for heavier/soiled items. Or, if it agitates with the lid open but doesn't spin, leave the lid open for the wash so it stops at the end so you can come back and reset it for more wash time. 2) Run the Regular cycle but reduce the wash time, and stop the machine for a 30-mins soak during the wash period to allow detergent enzymes more time to work on soils. |
Post# 1099912 , Reply# 11   12/8/2020 at 23:35 (1,234 days old) by RP2813 (Sannazay)   |   | |
Those are good suggestions if you happen to be stuck with a Speed Queen that's been possessed by a Shredmore, but if I had paid full price for a new SQ, I would sure as hell want it to do its job without damaging clothes -- and do it automatically as well. This machine sounds like a major inconvenience as is and an even bigger one with all of that babysitting.
Post# 1099925 , Reply# 13   12/9/2020 at 05:22 (1,233 days old) by 70skid (Texas)   |   | |
Post# 1099934 , Reply# 15   12/9/2020 at 07:51 (1,233 days old) by Frigilux (The Minnesota Prairie)   |   | |
Speed Queen Toploader: I'm on team check-for-a-snag, as well. There may be a small, sharp nick in the agitator or the tub somewhere. While my 2017 9-Series is not as kind to fabrics as the front-loaders that preceded it, the only issue I've had is that it sometimes likes to pull a loop/thread on bath towels. Otherwise, no problems with ripping or tearing.
Post# 1100691 , Reply# 17   12/15/2020 at 08:37 (1,227 days old) by 70skid (Texas)   |   | |
If you want a traditional loud machine that uses its belt as a clutch.....then by all means....go with the TC5. Must be the last one made with drivetrain design that is older than your DD.
That said, SQ now has the TR7 machines programmed with longer duration and more aggressive agitation routines such that they receive Consumer Reports 4/5 cleaning score in Normal Eco (same as TC5) while using less water, producing less noise, and offering a longer warranty. Look up TR7003WN for the latest test score. Replaces TR7000WN. My real world experience is that the TR7 and TR5 both work well. I have a 10 year warranty on the TR5 (2019 warranty special) and a 7 year warranty on the TR7. They just need to be loaded properly and always use AutoFill. |
Post# 1100924 , Reply# 20   12/17/2020 at 09:20 (1,225 days old) by 70skid (Texas)   |   | |
OP, the TR uses plenty of water. It will automatically put in the optimal water level for the load whereas the TC5 has two levels (half and full). You can also select full tub on the TR, if you insist, but using too much water degrades performance with this wash action design.
Just don’t get scared off by people deriding the TR based on the 2018 model. The 2020 ‘003’ models match the TC5 in Consumer Reports’ stain removal testing using Normal Eco. Using Heavy Duty / Heavy Soil settings....the TR can do a great job cleaning clothes. You can use as much water as you like, with extra rinse, etc. If you want speed, the TC5 cleans faster, as another poster said. |
